Nick, The nearest you will probably get, going by my catalogue here in nz is listed as Engineering Tube 44.5 mm OD x 2.64 mm wall, or 44.5 mm bore x 2.03. With plumbing tube it goes from 40 mm to 50 mm. Oops, just found Australian Standard 1432-1973, water gas, sanitation, type (B) 45 mm x 1.2/ 1 3/4" x 18g, and type (D) 45 x 0.9, 1 3/4" x 20g.
So all you need is a supply Warehouse, and select the required wall thickness. The catalogue even gives the bursting pressure for annealed copper tube, you can get it annealed or hard. If you are lucky you might get an off cut, maybe part of a damaged tube. If you can go to the sales outlet, tell them what you want it for, this sometimes helps.
Try Master Trade.
Ian S C
Edited By Ian S C on 07/04/2016 15:01:05
