Look for something like Kaowool, its a manmade fibre. I’m using two layers of teh 1/16″ thick with a sheet of baking foil between on my Fowler (5″ boiler, 1/8″ gap) you can get it in thicker sheets or just double up. Not expensive you should be able to do a 6″ boiler for under a tenner.
If you can’t find it then M J Engineering stock it.
J
Edit blackgates also do teh Kaowool in 1mm, 2mm and 1/4″
Edited By JasonB on 03/03/2011 15:41:26
