I have given up on my 3.5" Rob Roy boiler build even though it is outwardly completed. I will order one from someone with greater silver soldering skills than me. My priority is a finished engine I can trust and I feel I can get more from working out what went wrong with this boiler than chasing around more leaks. The point of this thread is to invite suggestions as to what went wrong as I may have another go on another locomotive sometime. I will also show the boiler to the inspectors in my club for their opinion.
This was my first attempt at boiler construction. I have used propane with bigger torches as I've gone along to get the heat into the boiler. I was seemingly on the right track right up to the last fittings ! After I fitted the backplate and foundation ring I did a 20 psi hydraulic test, no problems.
That just left the stays, blowdown valve and top fitting for the water gauge. I silver soldered all of these, using a long neck torch to get heat inside the firebox. All seemed to go reasonably well.
When I repeated the hydraulic test I had water running out at atmospheric pressure from the foundation ring ! I fixed that by a little hammer tapping, a PB screw and then re-soldering. At the next test I had a just weep or two at 20 psi inside the firebox at the seam near the tube ends. I re-soldered that. Now I have weeping at very low pressure somewhere from the tube ends. If the leak was anywhere else I would have another go but I feel every time I put more heat in there I create a new problem.
I have been using SS 55%, pickling and cleaning between every soldering operation and refluxing nearby existing joints when going back in to add the last fittings. Whatever I solder seems to work nicely, it's the surrounding areas that seem to be failing.
Thoughts ?
