New Photo Album created showing the abomination that is the method of getting oil to the Norton gearbox's gears.
At least that's how I see it, but I could of course be totally wrong.
As can be seen, there are screw-in 'Oil' plugs either side of the Control Base, with a thick felt 'Oil Gasket' under said 'Base', covering a multitude of holes strategically drilled in the gearboxes' top.
Now unless I am completely missing the plot, you would need to at least fully cover that piece of felt before any oil hopefully dripped through any of the holes, with most escaping down the sided of the gearbox.
The 'Control Base' isn't needed due to VFD with remote being fitted, so I'm looking for a more positive method of getting oil into the gearbox.
Spring oilers into each hole a possibility.
Just thought of another more simple solution though. With a hinged cover over the 'oil reservoir', oilers won't be needed, just squirt oil straight down the holes! . Woohoo, brain actually in gear this morning! Wonders will never cease!
Suggestions once more please.
Geoff – Brain will now go into reverse
