Bentley BR2 Rotary Aero Engine
Home Forums Miscellaneous models Bentley BR2 Rotary Aero Engine
  • #805721
    notlobgp14
      @notlobgp14
      Hello David Briggs here.
      I’m building a Bentley BR2 Rotary Engine.  Completing a project which some else started then became unable to complete.  Is there anyone else currently building or has completed this model?
      John Hinkley
        @johnhinkley26699
        David,
        Do you have a copy of the book by L. K. Blackmore that gives a description of his build as well as well as a full set of drawings, apparently?  Quite a few available from £9 for a slightly tatty secondhand copy up to ones costing a lot more, condition unknown.
        Cheapest that I’ve found. But is it still available?
        notlobgp14
          @notlobgp14
          Yes I “Inherited” the original builders book and Work in Progress
          #805855
            You might try asking on MEM Forum there are a few members there who like their radials. If you are anywhere near Guildford then Mike is quite likely to be there tomorrow for their open day and does not need much of an excuse to fire it up.
            #806036
              Just to confirm Mike is at the Guildford show today if you want to see his Bentley running.
              He also had his Winters work on display, a vertical Perkins, It was running a lot better before I got the camera out.
              #806038
              Vic
                @vic
                I’ve always found Rotary engines fascinating, so I had to do a google on the Bentley.
                https://youtu.be/UsyhOdRXsPA?si=XCglXH7KQc4m4uIR
                #806046
                  That is Mike Cole.
                  #806084
                  notlobgp14
                    @notlobgp14
                    <p style=”text-align: left;”>Jason</p>
                    Thanks very much
                    David
                    #806414
                    peter alcock
                      @peteralcock28509
                      David I am part way through the build of the third BR2, 2 from the Blackmore book and 1 from Ageless engines.   Happy to discuss any issues.  Peter
                    Home Forums Miscellaneous models Topics
