I think Andrew's demonstration was of potential rather than a recommendation to owners of small milling machines. Andrew shows that a Carbide cutter can be run much harder than most of us would be comfortable with.
A big disadvantage of cutting fast and hot is that the shower of smoking swarf is unpleasant. Making hot swarf on my lathe is particularly uncomfortable because it lands on your hands and arms, ouch. Extra nasty if it gets in your eyes. Slowing down makes the job more civilised.
What limits the speed a machine tool can remove metal is:
- The maximum temperature the cutter and job can take.
- The power of the motor, and the time the motor can deliver power before overheating.
- The rigidity of the machine, ie it's ability to apply power to the work via the cutter without vibration or bending.
- The strength of the machine – gears, belts, spindles, bearings, frame etc. What will break first if you over do it!
Hobby machines are less heavily built than professional machines, and their motors may not be rated for continuous operation. DC motors have brushes that wear quickly if the motor is flogged.
In practice, I:
- calculate an approximate rpm with 10000 / diameter (mm).
- increase or decrease the approximate rpm depending on the cutter and material I going to use. (6 to 4x faster with carbide, 20% faster with HSS if flood cooling.) Brass 20% faster than steel.
- Depth Of Cut – 10 to 20% of cutter diameter, but note the advantage of Andrew's point about using the full length of milling cutters where you can.
- Adjust the feed-rate for – in steel – straw chips with HSS, blue chips for carbide.
- MOST IMPORTANT – all of the above is to get into the zone, not a formula for guaranteed success. I listen for signs of stress – chattering, labouring, excessive noise, belts slipping, poor finish – and back-off until the job is cruising. This part has to be learned by trying. I suspect I'm too gentle.
As operator faults go, being over-cautious produces disappointing results especially if tools rub rather than cut. But being over-cautious is unlikely to damage the machine. At the opposite end, some people have gross over-expectations. If you wind the tool up to full power and smack the cutter into the job (causing severe shock loadings), and then force the cutter through the work ignoring signs of stress, then expect blown fuses, worn brushes, damaged electronics, broken sheer pins and stripped gears.
Attitudes to machines vary as well. If I owned a fine watchmakers lathe I would treat it with respect. I see my Chinese kit as consumable. If my lathe lasts 5 years, it only cost £1 per day. If I wear it out or expensively break it, I'll replace it. Going well so far, light to moderate use, kept clean and oiled, no sign of wear after 4 years.
Edited By SillyOldDuffer on 07/08/2018 11:39:49
