My recollection of the MEW one is that it was a minor variation on a pin striking a star wheel. I don't think I was too happy with the choice of material in places.
Actually I wasn't asking about it but suggesting Neil might post it as a freebee that might be of interest to others but it seems that it isn't old enough. I thought i had a copy of the edition that it was in but it seems to have gone awol. It took the magazine for a while after it came out but didn't find much of interest so stopped buying it. The things I generally find of interest in a mag are the unusual tools not common ones.
In terms of tooling I might make I have interest in a toolpost grinder, tool grinder and finishing a rotary table I started some time ago. Stopped because a small home made one came with my Dore Westbury. Also the alignment of a Chinese lathe I was making it on. My Boxford is more than capable of doing the work. The home made one needed a little bit of extra work to make it work well but when a strap fitted to it was removed the casting cracked. It still works well enough but I should finish the other one. My dividing head is home made too and too small really. Another job maybe at some point but I might just fit a bigger worn wheel to it.
Boring head I have. It's more than adequate, home made and probably on it's 3rd owner at least. I can get it to face on the mill if needed.
My immediate aims are to replace the front bearing on my Boxford as I suspect it will cure a minor niggle I have with it. Finish off sorting out a Pultra and also starting on a Wabeco 4000 that I feel should turn a little better than it currently does. I've already bought a bigger rack feed handle for it and a spring guard for the lead screw. Plus a replacement tool post for it. I can get a decent parting off tool on it now.
At least my tidy up and sort out is showing slight signs of finishing. I'm absolutely gob smacked how many reamers I have now they are all together. I've nearly found everything I thought I had now too. Just a few things to go.
