ACME vs lead screw
ACME vs lead screw
Home Forums Beginners questions ACME vs lead screw
  • #405478
    Harry Crowther
      @harrycrowther39896
      Hi,
      I was wondering if anyone knows the difference between a 'trapezoidal lead screw' and a 'ACME lead screw'? Or is ACME the brand name?
      Harry Crowther
        @harrycrowther39896
        #405489
        Brian G
          @briang
          They are both trapezoidal Harry. Generally I think the difference is whether the machine is imperial or metric. Acme (named for the Acme Machine Company) has a thread angle of 29 degrees and dimensioned in inches, whilst ISO trapezoidal threads have a thread angle of 30 degrees and are dimensioned in mm. I suspect however that in the long tradition of mixing standards you can get metric machines using the Acme thread form or imperial machines using the ISO form.
          #405559
          Zane Crowther
            @zanecrowther67531
            There isn't much difference as mentioned above, its just that the American ACME form has an angle of 29 degrees, while the metric trapezoidal is 30 degrees. So trapezoidal lead screws are more common in the UK.
            #405560
              You will also find that ACME is made in imperial pitches given as tpi or threads per inch whereas the Trapezoidal come sin metric pitches eg 2mm , 3mm etc.
              I would not say TR screws are more common in the UK as there are still a lot of old machines running imperial ACME screws but anything new and metric will have TR
