A good quality oil can..?
Home Forums General Questions A good quality oil can..?
  • #25490
    choochoo_baloo
      @choochoo_baloo
      choochoo_baloo
        @choochoo_baloo
        I've not had much luck buying a reliable oil can.
        Tried two new Wesco cans and neither would pump (I wasn't impressed with the plastic construction anyway). Tried some unbranded one from soke general tool stand – pile of crap!
        However I am very happy with a Reilang precision oiler; I can't believe in this day and age they're the only quality suppiler (I cant spend that price for *every* new oil can!)
        Recommendations for workshop use please.
        Edited By choochoo_baloo on 10/09/2017 20:08:56
        #316427
        JohnF
          @johnf59703
          A Reilang oil can, just google it or try one of the suppliers on the forum, yes they are expensive but they work faultlessly and the pump works whichever way up you are using it and doesn't leak !
          #316436
          DMB
            @dmb
            I reckon that my Reilang must have paid for itself in cost of oil not spilt.
            The awful Wesco spilt as much as was used. I have one or two other similar designs and they are all useless.
            Not just cost of wasted oil but the mess and it soaks into absorbent surfaces such as a wooden shelf, making it impossible to clean up.
            Get what you pay for again.
            #316443
            thaiguzzi
              @thaiguzzi
              I have a Reilang but it's a big one, too big for ball oilers on machine tools really, it has a non flexi spout and the big alloy body gets in the way. Excellent oil can though. retired to the assembly/engine building shop.
              My go to oil cans in the machine shop are small no-name Chinese 350ml steel, come with fixed steel and flexi spouts. Cheap as chips (about 3 quid a piece), robustly made, no plastic internal or externally, used daily for years, and if they break, buy a new one, it aint breaking the bank. I'm sure they are available in the UK.
              #366963
              Ady1
                @ady1
                I've got one of those wesco 350 square green plastic can oilers and it's been really good to me
                The spout is a fixed see through plastic
                #366969
                I.M. OUTAHERE
                  @i-m-outahere
                  You can also get plans for a home made version of the American made Eagle oiler .
                  #366979
                  Mark Gould 1
                    @markgould1
                    +1. Another vote for the Reilang. Buy the metal body type though. I have had a plastic Reilang before but it wasn’t very good at all.
                    Edited By Mark Gould 1 on 12/08/2018 20:04:30
                    #366981
                    martin perman 1
                      @martinperman1
                      I cant remember the name but I use two oil cans I bought from Halford's, flexible spouts and steel bodies, don't leak and get a lot of abuse when trying to oil a running engine.
                      Martin P
                      #367341
                      Howard Lewis
                        @howardlewis46836
                        Have several oil cans of various vintages. Wescos are used for general "oiling". The genuine oil gun one for the Myford put oil everywhere except through the nipples. My smaller Reilang puts through ball oilers with rarely any leakage.
                        I got what I paid for, initially expensive, but never lets me down or causes problems. What more can one ask?
                        #368469
                        Ady1
                          @ady1
                          I tried the 350 square green one with a bendy see through spout from the usual suspect and it wouldn't pump to start with
                          So I turned it upside down for a few seconds to let the oil seal up any air gaps and now it's working fine, plenty of control if I want to put a teeny bit on
                          #368478
                          Martin King 2
                            @martinking2
                            Reilang, Eagle, BIB (french) all excellent, have sold loads of them and never had a complaint.
                            Cheers, Martin
                            #368492
                            Mike E.
                              @mikee-85511
                              Here's a thought….. Why not make your own ?
                              I often see metal hip flasks for a couple of pounds in charity shops. Machining a simple drip nozzle replacement cap with an O-ring would make for a handy size oil can.
                              #369578
                              daveb
                                @daveb17630
                                Posted by Mike E. on 22/08/2018 18:34:28:
                                Would ye care for a wee drippy?
                                #369598
                                Vic
                                  @vic
                                  Posted by Ady1 on 22/08/2018 17:03:39:
                                  I tried to use my flexi spout oiler the other day after filling it up. It wouldn’t work at all and I nearly threw it in the bin but for some reason I turned it upside down and gave it some pumping and it started to work. I hope I remember this next time I need it!
                                  #369874
                                  Meunier
                                    @meunier
                                    Looking to oil up the ML7 now it's back on its feet, and dreading using the old Myford oiler. Could those who chose a Reilang oil-can (200ml? is that the best size) say whether they chose/prefer a rigid or flexible delivery tube .
                                    Thanks
                                    DaveD
                                    #369897
                                    Don Cox
                                      @doncox80133
                                      Last year I was given a whole load of tools by the family of a professional model engineer (yes really, he made models, mostly ships, for the Admiralty and later the MOD). In amongst these were two Valvespout oilcans which didn't look much but have proved to allow injection of Nuto 32 oil into all of the oilers on both my Myford ML7 and S7. The nozzle is small enough to allow me to push the balls off of their seats in both the grease nipple type and the original flush ball type of oiler, oil can then be introduced into these with ease and there is very little wastage or mess. The ones I have look like this: https://www.ebay.co.uk/itm/VINTAGE-MULLER-Co-VALVESPOUT-OIL-CAN-EXCELLENT-CONDITION-CLEANED-WORKING/352448843091?hash=item520f968d53:g:EV8AAOSwyUtbfrN6
                                      Don Cox
                                      #369919
                                      Mick Henshall
                                        @mickhenshall99321
                                        I think I have been persuaded to buy one of these Reilang cans, the 200ml metal one hopefully will sort the ball oilers
                                        Out on my Shaper
                                        Mick
                                        #369928
                                        Hopper
                                          @hopper
                                          I have a cheap Chinese oil can with brass pump mechanism submerged in the oil in the usual manner. But it SQUEAKS like a dry door hinge every time the plunger is pushed down or released. How can they make a mechanism that is completely submerged in oil squeak?
                                          #369947
                                          Stewart Hart
                                            @stewarthart90345
                                            Make your own this design was published in model engineer last year.
                                            I've made two and they work perfectly, you can get the material to make 1/2 dozen for the cost of a railing can.
                                            Stew
                                            dsc02833.jpgEdited By Stewart Hart on 01/09/2018 15:46:27
                                            Edited By Stewart Hart on 01/09/2018 15:47:28
                                            #369951
                                            not done it yet
                                              @notdoneityet
                                              Tried and tested since 2012? Or is the camera date telling fibs?
                                              #369952
                                              martin perman 1
                                                @martinperman1
                                                Posted by Hopper on 01/09/2018 12:56:29:
                                                It is most likely hydraulic creaking as the oil is pushed through a hole.
                                                Martin P
