Lee
I think Jason meant this link : http://www.rotagriponline.com/index.php?page=shop.product_details&product_id=3534&flypage=flypage-ask.tpl&pop=0&option=com_virtuemart&Itemid=29
160 mm standard accuracy Pratt Burnerd for £ 351.90. Safe to 3000 rpm which is nice. No specifications as to axial alignment, concentricity and run out tho'. Its an import of course but probably more of a warm cuddly feeling from buying via a major industrial supplier. Hafta say there was an moderately minor issue with the new PB chuck I got back in the day and that was sorted with no quibbles. Chucks'R Us shop types wouldn't have wanted to know.
With an integrated fitting chuck these need to be good out of the box as there is no possibility of adjusting thing. Theoretically a backplate fitting can be adjusted to compensate for any chuck body errors. Monumental faff if you want to get to thou' and below levels. Oft talked about but I wonder how many people have actually done it. Considerably different than getting better results from a 40 year old worn out chuck.
In a practical world its the axial alignment with the spindle that really matters and that is something readily got dead right with a backplate.
In todays market pretty much all but the stupidly cheap stuff has generally acceptable performance so there is much merit it Johns suggestion of getting a reasonable, but relatively inexpensive chuck and backplate. Maybe save £100 over a respectable integrated fitting version. But if you go for brand name equipment Pratt Burnerd / Bison / TOS et al chuck and backplate will come out more than an same chuck on an integrated fitting.
Clive
PS Slow typing.
Edited By Clive Foster on 20/06/2017 11:34:28
Edited By Clive Foster on 20/06/2017 11:35:38
