Reply To: Twinner Multi-Jigset (what is this tool for?)
Home Forums Workshop Tools and Tooling Twinner Multi-Jigset (what is this tool for?) Reply To: Twinner Multi-Jigset (what is this tool for?)
#559838
    Thanks to Robert’s discovery … I have just found this:
    Improved Welding Technique. — A new
    development to be included in the 1952
    British Industries Fair, to be held in
    London and Birmingham from May 5
    to May 16, is an improved method of
    welding known as the "Twinner Tech-
    nique''. The basic idea is that universal
    holding tools are set up on the top plate
    of a welding positioner to receive the
    workpieces to be welded. The holding
    tool acts as a jig, and being mounted
    on the welding positioner, the work-
    piece can be positioned to suit the weld-
    ing procedure. Complicated weldments
    can thus be built up rapidly from a
    series of sub-assemblies with special jigs,
    the sub-assemlies being brought together
    as a final assembly on the welding posi-
    tioner.
    This method is claimed both to econ-
    omize considerably in production time
    and to eliminate the cost of special jigs.
    The ''Twinner Technique" is made by
    Donald Ross and Partners. Limited. 1-3
    Arlington Road, London, N.W.I.
    Ref. **LINK**
    https://archive.org/stream/transactionsofen35engi/transactionsofen35engi_djvu.txt
    and also another address [in 1964] , at Twinner Works, Gatwick Road, Crawley
    Keep digging !
