Reply To: Can you recommend a UK supplier for good quality “mill board”?
Home Forums Materials Can you recommend a UK supplier for good quality “mill board”? Reply To: Can you recommend a UK supplier for good quality “mill board”?
#549739
John Smith 47
    @johnsmith47
    @Bill Phinn
    Yes, I have already had a few samples from JPP about 3 weeks ago – thank you so much for the suggestion.
    Having spoken to them (James), they thought that their "JPP ARCHIVAL FOLDING BOXBOARD" (as per your link) would be too soft, as it is specifically designed to be folded and will not have the rigidity that I seek.
    [No, I can't use creasing of the card in order to create a hinge for a number of of reasons – not least because such creasing has a positional 'memory' and I shall use some sort of fabric /cloth or liner material to create the hinges.]
    JPP suggested their Heritage Conservation Board 1380micron, and sent me a sample of it, but it is way too soft and is for example very easily bent beyond it's elastic limit (i.e. creased!) between 2 finders and a thumb.
    However much more to the point is their "Gemini Mill Board" – which is fantastic stuff!
    e.g. I definitely cant bend their 1.5mm Gemini board between fingers and thumb. However my problem is that they simply don't make anything between 1.0mm and 1.5mm.
    To get clear 1.0mm is too thin to have much strength and 1.5mm is too thick for my requirements.
    [Part of the problem with the 1.5mm thick Gemini Mill Board is that it is unlined, and in order to make it durable and give it attractive, cleanable, moisture-resistant finish, I will need to bond some kind of paper, plastic film or book cloth onto both the sides of it once it is bonded into the 2 layers I need. And that will make it quite a lot thicker than my overall thickness (of the 2 layers) of being 3.0mm.
    For example most of the protective papers & films that one can obtain from the likes of Winter & Company are between 0.15mm and 0.20mm thick. So assuming 2 layers of film – one on the inside of the box one on the outside of the box (especially allowing for a little adhesive) the total thickness in mm would be something like:
    0.15 – Protective film (minimum)
    0.05 – adhesive (guess)
    1.50 – Gemimi Mill Board
    ==> nearly 3.5mm (i.e. 3.45mm), which is a LONG way past my target of maximum of 3.00mm.
    @SillyOldDuffer – all true. However I am trying to make something that a high volume, mass production licensee company would be interested in making, is low in cost, can easily be recycled as well as having a reasonably good strength-weight ratio.
    – Steel that is tin-plated will be too heavy for its rigity
    – Aluminium & brass are both too expensive
    @Michael Gilligan – I googled DEF-STAN and got lots of UK MOD stuff. Is that what you meant?
    I wasn't sure how to apply that to this situation.
    @Roger Best – Yes, a Box file is close to it, however all the walls have to be the same thickness, and they have to be hinged accurately.
    @Journeyman – Yes, I am extremely familiar with the Really Useful boxes. However they do not have collapsible side walls.
    REQUEST: Please can everyone stick to my original question. I am just looking for UK suppliers of good quality "mill board"! For some reason I am finding them hard to locate through Google…
    So still I need a strong Mill Board that is about 1250 to 1400 microns thick.
    Cheer
    J
