Boring large diameter hole in aluminium bar
Home Forums Beginners questions Boring large diameter hole in aluminium bar
  • #315105
    Hillclimber
      @hillclimber
      I have a short piece of 4" diameter 6082 aluminium in which I need to bore a concentric 2" diameter hole to a depth of about 2" in my S7.
      Question in how best to do this? A boring bit sounds awfully long and slow, and I am unsure how best to manage that as a procedure? Should I stick it on the vertical slide and try a mandrel mounted boring head?
      Cheers, Colin
      Edited By Hillclimber on 04/09/2017 07:59:52
      #8854
      Hillclimber
        @hillclimber
        #315107
        Brian Oldford
          @brianoldford70365
          How long is it?
          #315110
          Marcus Bowman
            @marcusbowman28936
            I have recently done much the same thing, for several workpieces. In aluminium, machining speeds are so high this is not a terribly lengthy job using large drills then a boring bar, compared to the same thing (also recently undertaken) in steel.
            I mounted my AL in the chuck, drilled to 19mm, then used a toolpost-mounted boring bar and power carriage feed.
            I used a tipped tool with an insert designed for AL (mirror polished, and with an aggressive rake). You have little chance without that, as an HSS tool will clog in seconds, especially at higher speeds without a lubricant. Using the insert, I machined the work dry, although flood coolant would be better. Coolant will also help prevent HSS tools clogging, but not for long.
            I also changed the speeds as the diameter of the bore increased, to stay within the efficient cutting speed range.
            The grade of AL also makes a huge difference. I used 6082 (HE30). 7000 grades are even better, but much more expensive.
            #315111
            Ady1
              @ady1
              Put it on the 4 jaw.
              Drill it as big as possible
              Open out with a boring tool so you can get a toolbit in
              Bore with a decent hss tool via the backgear to reduce heat issues.
              Finish off at higher speed
              Alternatively, drill a hole in it it, then surface cut it (face cut) to depth with a hss tool
              #315113
                Get an isert bar with a CCGT type tip designed for aluminium and it will fly through it. Did much the same a couple of weeks ago, biggest issue is the swarf which can come off a bit long and stringy.
                #315123
                Mick B1
                  @mickb1
                  An HSS boring bit will work fine if you get the rake right, keep it sharp, and polish the top and tip radius with a slipstone to stop it picking up.
                  #315150
                  duncan webster 1
                    @duncanwebster1
                    If swarf sticks to tool give it a squirt with WD40. HSS plenty good enough in a S7
                    #315172
                    Hillclimber
                      @hillclimber
                      Posted by Brian Oldford on 04/09/2017 08:03:42:
                      How long is it?
                      The piece I am working with is 2" in length. The finished length (as I have some other procedures to perform) will be 1.25". Finished article should look like the piccie, but smaller diameter.
                      #315176
                      Hillclimber
                        @hillclimber
                        Posted by JasonB on 04/09/2017 08:20:37:
                        Jason, something like this?
                        http://tinyurl.com/y7wul957
                        Attractive idea, but I have just taken a look at recommended cutting speeds with this combo, and I'm seeing 2800 fpm? So a modest 5000rpm at 2" on my S7?
                        Edited By Hillclimber on 04/09/2017 16:52:47
                        #315180
                          I have exactly the same bar in my collection works fine at lower speeds, my WM 280 hardly ever runs in the high range so that means I'm below 950 rpm. Something like 500rpm will be fine as you get towards the 2" dia, bit faster as you start to open up the drilled hole.
                          This is a 2.125" hole in a bit of 5" bar that I mentioned earlier no need for production speeds.
                          #315182
                            I bored a 2 1/2" diameter by 1" deep hole in the cast iron body of my rotary table.
                            I survived…
                            Hillclimber
                              @hillclimber
                              Jason, looks like a perfectly good job to me!
                              Is that a four-jaw you're holding it in?
                              #315186
                                Yes, 6" 4- jaw as there would not have been much scroll engagement if I had used my 5" 3-jaw. The same tips will work well on the external surfaces. If you don't have other holders then the facing can be done with that boring bar by cutting from the middle out once a hole has been put in the middle.
                                As others have said a bit of WD40 or paraffin will help a lot as it stops metal sticking to the tip.
                                This is the outsid eof teh same part co-ordinate turned to profiel using a similar CCGT tip
                                #315256
                                John Reese
                                  @johnreese12848
                                  Posted by Hillclimber on 04/09/2017 16:37:23:
                                  The performance of a properly polished insert will be satisfactory at much lower surface speeds. Your insert should last a lot longer as well. 2800 fpm is likely based on acceptable tool life (heat related) in an industrial application.
                                  #315263
                                    Not sure where you got 2800 from – maybe an order out?
                                    I very much doubt you have a chuck that would run safely at 5000rpm! Let alone a lathe that could achieve that speed.
                                    #315266
                                    John Olsen
                                      @johnolsen79199
                                      Since the hole is to go right through, why not start it with a hole saw? They will usually go to about two inches depth and will leave you with a potentially useful slug of metal from the inside, instead of a skip full of swarf.. You can actually go in from both ends if necessary, giving the possibility of a hole up to nearly four inches long. You do need to back them out a lot, as there is no real path for the cuttings to get out so they will load up the teeth. I have done this in cast iron as well as in aluminium. It may not be any faster than just drilling and then boring, but I hate to waste good material. Choose a hole saw that leaves just a small amount to take out with the boring tool to clean up.
                                      Marcus Bowman
                                        @marcusbowman28936
                                        RPM = cutting speed (metres/min) / circumference (metres)
                                        Aluminium has by far the highest recommended cutting speed of all the common materials in our workshops, at 75 to 105 metres/min for HSS tools and 900 to 2200 metres/min with an uncoated polished insert.
                                        At the lower end, on a 50mm diameter bore, that translates to 500 – 668rpm for HSS and 5732 – 14102rpm for a tipped tool. Two limiting factors have already been mentioned: lathe top speed and chuck rating.
                                        So; run the lathe at top speed, but expect the carriage feed rate to be slow. The tipped tool rpm are well outside the Myford/Boxford/mini-lathe speeds, but that will not prevent the tips working reasonably well. I certainly would not be inclined to attempt this job with HSS tools, but opinions (and results) vary. I machine aluminium frequently on the lathe and the mill and have found the tipped tools or polished carbide cutters ground with cutting angles specifically designed for aluminium to be the answer to the clogging and sticking problem. Flood coolant helps too, of course, if you can stand the mess. WD40 stinks too much for me. Carnauba wax works too, but is too laborious to apply, and too expensive. Neat cutting oil works, as does water-soluble cutting oil. Application by toothbrush is too much effort, on a time-consuming job like this.
                                        Some manual lathes (Hardinge, for example) can run at 5000rpm, and suitably rated chucks are available at a price.
                                        The smaller diameter stages of drilling and initial boring will work best at correspondingly higher rpm.
                                        In the end, we do what we can with what we have, and a 50mm hole is perfectly achievable without too much difficulty (except, as previously noted, for the copious swarf).
                                        Despite the higher recommended speeds, I would simply use top speed and be content with the chrome-like finish on the final finishing cuts. Wondrous to behold.
                                        Two other points:
                                        The work needs to be gripped in such a way that there is clearance behind the work for the cutter to pass through without hitting chuck or faceplate, at maximum cut diameter.
                                        The boring bar for the final stages needs to be stiff and/or of large diameter, to prevent 'ringing', and to provide sufficient rigidity for the finishing cuts. It depends on the finish you need on the job.
                                        Marcus
                                        #315324
                                        Hillclimber
                                          @hillclimber
                                          Marcus, thanks for that addition. Not quite sure how to handle lubrication yet, but you very much confirm where I was getting to – just run the lathe as fact as I can. And, yes, talk of 5,000 RPM on my S7 was intended as ironic (ferric?).
                                          Figure I'll buy a couple of boring bars from someone like Arc (8 and 12mm) and just tuck in. I think the idea of using a holesaw is good, but will keep that one for harder materials.
                                          Really appreciate all the help. Many thanks to all.
                                          Cheers, Colin
                                          #315405
                                          Marcus Bowman
                                            @marcusbowman28936
                                            Although 8 and 12mm bars are useful, I made an additional larger diameter bar with an HSS tip for finishing cuts on larger bores. It's 25mm diameter and much more rigid than the smaller bars. Although the tip is an inserted bar of HSS, it is fine for 2 or 3 fine finishing passes (all of the same depth of cut). It is a bit of a chore having to remove the 4-way toolpost and mount the big bar, but I have found it pays dividends. One of these days, I will make a similar bar which takes a polished tip insert. As you probably know, those polished inserts are available with different tip radii, and the slightly larger radii are ideal for smooth finishing cuts.
                                            I have bought nice inserts and bars, and other tooling, from http://www.shop-apt.co.uk (with whom I have no connection).
                                            Marcus
                                            #315452
                                            Jon
                                              @jon
                                              No need for the extravagance of a tipped boring bar that most likely wont be that good.
                                              Biggest drill you have straight through then merely open it up 1 to 3mm cuts feeling for whats happening.
                                              Power feed in reverse for final cleanup. Keep a knife handy to prise the aluminium off tool, no WD would suffice only flood coolant and close to chuck flings off.
                                              Heres a quality British carbide 1/2" round ground up I used to use on my old ML7, just angle it in a few degrees to reduce the flex.
                                              Aluminium is 6082 5 1/2" dia x 3/4" thick using same chuck used on ML7 some years before. Bore around 1 3/4" here may be more.
                                              ML7 done about 200 this way usually 4" and 4 1/2" dia and still continue 24 years later this way with a variety of tipped now in excess of 2000 done.
                                              If your worried about ripping it out heres another action shot 1000rpm on 5 1/4" dia 6082 x 1" long, 5 1/4" Bison 3 jaw chuck and powered cross facing off 1/2".
                                              Its also the smallest chuck can fit to an L00 and D1-4.
                                              ML7 will have to check clearance over cross slide or set tool appropriately.
                                              #315492
                                              Hillclimber
                                                @hillclimber
                                                Jon, why do you have to make it look and sound so easy? Do you realise how annoying that is for mere mortals?
                                                Many thanks for this. Truth is that my ability to grind a tool is probably up there with my skills as a jet pilot – I would trust neither. So it is an attractive solution, but the idea of using inserts provides better assurance of the important sharp edge.
                                                But some other lessons in there too – like using a small chuck if I'm going to up the cutting speeds.
                                                As an aside, have you ever considered opening the Lodge to we mortals and offering workshops in the traditional black arts such as tool grinding? My guess is that a line of ticket buyers would form pretty quickly. And we would even promise to sign waivers on H&S issues provided you agreed to remain liable for the quality of the coffee.
                                                Cheers, Colin
