A while back i got a boring head for Xmas (my sister felt it very appropriate).
I've used it a few times, but I seem to have trouble with the bars.
These have 12mm round shanks and came in a set of 9 (from glosester tools, I think).
I've only used the shorter ones as my mill (CMD10) travel is only 30mm at most and anything longer would only reduce rigidity (which is not there in large quantities at the best of times).
What I seem to find is that the bar ends up with end end rubbing against the cylinder I'm cutting rather than the carbide tip cutting. This seems to get worse as the radius of the cut increases, though I'm noticing this after the bore is finished and not whilst it happens, so I'm not really sure.
There is a huge amount of spring in the system. I reckon that the bore is being undercut by 0.5mm or more. Obviously taking a number of cuts improves this, but I'm struggling to bore to size. It seems to measure OK when in the mill, but be bigger when I get it out. I expect this is dumb operator syndrome, but…
I'm typically boring out a 10mm hole to around 20mm (and about 25mm deep at most) so I'm not attempting anything terribly difficult.
At least one of the bars is now unusable – the tip has actually bent back – and the second is a bit dubious.
Apart from seeking expert advice, I'd also like to buy some more bars, but I only seem to be able to find either long bars for a lather or the sets of 9 which I'm not too happy with (usually coming with a head).
Assistance, advice and rude comments all welcome!
Iain
