I intend to manufacture some changewheels for my old Drummond round bed lathe.
The few changewheels that came with the lathe are pretty battered, especially with the two pin locating holes. I am told that the two holes take tapered locating pins. It is very difficult to check, as at some stage, the holes appear to have been drilled oversize. As I intend to make a new set of wheels , I may as well do this as Drummond intended!
So the queries are,
1/ Do one, or both holes have a taper? If so, is this a standard taper like the usual 1 in 40 taper?
2/ If only one hole has a taper, then what was the original straight pin diameter?
3/ If both holes have a taper, then do they taper in the same or opposite directions?
I appreciate that it isn't too important to get the details correct (except maybe the answer to 3/). But no point in getting them incorrect and then finding that the wheels do not fit on other Drummond lathes!
Thanks for any information, as it does not seem to be readily available here or elsewhere.
Andrew.
