PERFECTO LATHE
PERFECTO LATHE
Home Forums Beginners questions PERFECTO LATHE
  • #286560
    phil1962
      @phil1962
      hi fellas new to all this but here goes I have a lathe that was made in Leicestershire its called a Perfecto Lathe is there any info on this lathe would it be metric or imperial is there a screw cutting chart for this lathe I read its the same as the myford ml2/4 also the Zyto any help would be grateful ATB Phil
      #8588
      phil1962
        @phil1962
        #286572
        Jim Nic
          @jimnic
          Have you looked at the brilliant lathes.co.uk site? Lots of info there and it would seem that a screwcutting chart is available from him.
          Jim
          #286573
          phil1962
            @phil1962
            my lathe
            Edited By philip walker 1 on 01/03/2017 10:55:02
            Edited By philip walker 1 on 01/03/2017 10:55:13
            #286574
            phil1962
              @phil1962
              Edited By philip walker 1 on 01/03/2017 10:57:16
              #286575
                @mike89748
                There's a fair amount of information on the Lathes & Co website – go to http://www.lathes.co.uk/perfecto/index.html
                I had one of these bought from new in the early 1970s. It was OK as long as you didn't expect too much of it, but it soon let you know you were over-working it by starting a dreadful chatter which led to poor surface finish. Mine was imperial – I don't think there was a metric version. I replaced it with a Myford ML7R, which was far superior.
                Hope I haven't put you off. You will get some good work out of your Perfecto is you treat it kindly!
                #286576
                phil1962
                  @phil1962
                  cheers not doing nothing to big just small parts I tried that site but don't give you the screw cutting chart would it be same as myford ml2/4 ?
                  #286578
                  phil1962
                    @phil1962
                    Posted by Jim Nic on 01/03/2017 10:53:48:
                    Jim
                    Thanks Jim ATB Phil.
                    #286586
                    Journeyman
                      @journeyman
                      Hi Phil, I started with a Zyto (very similar) many years ago (now have Warco WM250) . That little lathe will get you going nicely. You may want to beef up the benchtop a bit though (looks like 1/2" ply) you will find it resonates and leads to chatter. A length of kitchen worktop placed on top of the ply would be good, and easy to clean down too.
                      Cheers, happy turning
                      Edit: spelling
                      Edited By Journeyman on 01/03/2017 11:47:54
                      #286588
                      phil1962
                        @phil1962
                        Posted by Journeyman on 01/03/2017 11:39:38:
                        Hi Phil, I started with a Zyto (very similar) many years ago (now have Warco WM250) . That little lathe will get you going nicely. You may want to beef up the benchtop a bit though (looks like 1/2" play) you will find it resonates and leads to chatter. A length of kitchen worktop placed on top of the play would be good, and easy to clean down too.
                        Cheers john I have now added another sheet of 3/4 ply on top of this so around 1 1/4 thick now yes its a super little lathe its my first one its very quiet to just ordered some new cutters as the ones that came with it were all damaged it will do to get me started and only making small things at the moment so should be ok for that
                        #286589
                          @mike89748
                          The pictures in Phil's posts show a machine exactly the same as mine. One quirk was that the carriage handwheel worked in the opposite direction to that on any other machine I have ever used – you turned it clockwise to advance the carriage the left. I think what really limited the machine's performance was a rather weak headstock bearing. I note that the very last Perfecto machines had a roller bearing headstock, which must have been a great improvement.
                          #286595
                          Mick Henshall
                            @mickhenshall99321
                            Mike- my Corbett lathe has the same set up turn clockwise to advance saddle towards the chuck, its never been an inconvenience for me
                            Regards Mick
                            #286596
                              Drummond Screwcutting Char
                              Threads Mandrel driven driver driven driver leadscrew
                              9 40 1 1 1 1 45
                              10 40 1 1 1 1 50
                              11 40 1 1 1 1 55
                              12 40 1 1 1 1 60
                              14 20 1 1 1 1 35
                              16 20 1 1 1 1 40
                              18 20 1 1 1 1 45
                              20 20 1 1 1 1 50
                              22 20 1 1 1 1 55
                              24 20 1 1 1 1 60
                              25 20 1 1 25 20 50
                              26 20 1 1 1 1 65
                              28 30 1 1 35 20 60
                              32 30 1 1 40 20 60
                              36 30 1 1 45 20 60
                              40 30 1 1 50 20 60
                              114.4 20 55 30 60 25 65
                              171.6 20 55 25 60 20 65
                              260 20 65 20 60 30 100
                              #286597
                                Had to split the postt as too large
                                Where there is "1" it is just to make the spreadsheet calculations work (in the part of the sheet not shown here) so just leave out or use idler gears to bridge the gap. You do not have to follow a chart slavishly it is just one way of getting the ratio needed. So if it shows 20 driving 40 you could use 30>60 or 25>50 if those are what you have.
                                #286598
                                  Metric
                                  pitch equiv tpi approx Mandrel driven driver driven driver leadscrew %
                                  0.75 33.867 33.846 30 60 65 50 20 55 0.06
                                  1.00 25.400 25.385 65 30 20 50 20 55 0.06
                                  1.25 20.320 20.308 20 1 1 60 65 55 0.06
                                  1.50 16.933 16.923 20 1 1 55 65 50 0.06
                                  1.75 14.514 14.505 20 30 35 55 65 50 0.06
                                  2.00 12.700 12.692 65 30 20 50 40 55 0.06
                                  2.25 11.289 11.282 30 1 1 55 65 50 0.06
                                  2.50 10.160 10.154 40 1 1 60 65 55 0.06
                                  2.75 9.236 9.231 40 1 1 60 65 50 0.06
                                  3.00 8.467 8.462 40 1 1 50 65 55 0.06
                                  1.75 14.514 14.545 30 1 1 60 55 50 -0.21
                                  2.00 12.700 12.727 20 1 1 50 55 35 -0.21
                                  #286602
                                  Scrumpy
                                    @scrumpy
                                    I had the perfecto lathe in the 1970 I completed several small stationary engines on it the only problem I had was getting the cutting tool to the correct height until I altered a myford multi tool holder to fit , You will enjoy it as it a good starting point
                                    #286603
                                    phil1962
                                      @phil1962
                                      Posted by Bazyle on 01/03/2017 13:00:58:
                                      Metric
                                      Thank you for this most help full so to cut a thread 26tpi I use a 20 on mandrel 65 on lead screw then any gear that will link them together is that right ? thank you
                                      #286619
                                      phil1962
                                        @phil1962
                                        Posted by Mike on 01/03/2017 11:51:36:
                                        Can you still get headstock bearing for this lathe if so were from just in case
                                        #286627
                                          @mike89748
                                          Hi Phil, Personal message sent, in reply to yours.
                                          #286629
                                          Anonymous
                                            Saves an idler gear and stub shaft in the saddle, so it's cheaper.
