Myford ML10 (later model) lubrication
Home › Forums › Beginners questions › Myford ML10 (later model) lubrication
Viewing 25 posts - 1 through 25 (of 26 total)
  • #279893
    Steve Langford
      @stevelangford34603
      Hello everyone,
      I'm not a complete beginner, but close enough. I have a Myford ML10 (Speed 10) lathe – it has the later taper roller bearings rather than the plain bearing headstock.
      My question is, what to lubricate the bearing with?
      The manual says to use lithium grease on a taper roller bearing machine, or oil on the plain bearing types. At the weekend, I tried to buy some appropriate grease from Myford, but the fellow said to just use the oil. I pointed out to him that the manual said to use grease, but he just shrugged and said that the manual was written 50 years ago, and was out of date as everyone uses oil these days.
      I'm not keen on that idea. I think if the manual said to use grease, even 50 years ago, that would be because grease is better for the taper roller bearings. The manual might be from a few years ago, but so is my lathe.
      Anyway, so I'd be keen to hear what other folks use to lubricate a taper roller bearing ML10, and how often (differing advice there too!).
      Many thanks
      Steve
      #8521
      Steve Langford
        @stevelangford34603
        #280108
        Andrew Tinsley
          @andrewtinsley63637
          Hello Steve,
          I use lithium based grease from Castrol, but just about all the manufacturers will have a lithium grease in their range. Try Halfords as a start, but you can get it from motor factors, usually much cheaper too!
          The first time I tried lubricating the bearings I rather overdid it and got grease all over the inside of the cover! Not good for the belt, that is for sure. I now open the cover and grease until I can see signs of movement around the rear roller. As to how often ………. well depends how much you use it. I would guess a good greasing would last about a 100 hours running. So it doesn't have to be done often. Although I am open to correction on this.
          Andrew.
          #280127
          Sam Longley 1
            @samlongley1
            Posted by Andrew Tinsley on 25/01/2017 16:45:16:
            Hello Steve,
            Andrew.
            As a comment/query
            I always thought that one should not put too much grease in bearings as it created heat.
            Is that correct?
            If one looks at sealed bearings there is very little grease in the bearing
            #280130
            Thor 🇳🇴
              @thor
              Hi Sam,
              You are correct, too much grease will make the bearings hot. It has been discussed on this forum, here's a link to what SKF says.
              Thor
              #280132
              HOWARDT
                @howardt
                We had a bearing heat discussion!! recently. Look at SKF with reference to your bearing number it will give you an indication of grease amount. Bearing should be greased with enough to cover the surfaces, usually about a third of the free space volume. Adding more will only cause heat generation.
                #280134
                  Lithium or moly (or teflon) grease will be fine. Oil is OK … if you have an oiler to keep them lubricated!
                  I've been told it's best to fill about 25% of the space in the bearing to avoid overheating and 'ploughing'.
                  Andrew Tinsley
                    @andrewtinsley63637
                    In my opinion, I would rather have too much grease than too little! But I bow to every ones knowledge on this!
                    Much more to the point how often would one grease? With the bearings in an ML10, how do you know how much grease you have put in the bearings. All very well saying 25% of the space etc when you cannot see how much you have put in. Correct me if I am wrong, but I can't see the grease quantity in my my ML10 bearings.
                    As to heat generation, I am not bothered about that. With lithium grease, the grease will run out of the bearing when hot, so it is more or less self limiting. I know this happens, because I see signs of grease coming out of the bearings for maybe the first hour or so of running, after greasing.
                    I am NOT trying to be argumentative, merely quoting the observations I have made on my ML10.
                    Andrew.
                    #280312
                    Clive Hartland
                      @clivehartland94829
                      There is a specific time period for greasing the ML10 bearings, something like 10 hours running and then one pump of the grease gun.
                      I do not recommend pumping until grease appears, as you found it will come out in quantities and clart everything up.
                      I could check but I have no wish to go outside at the moment as the temperature is minus 2.5 C.
                      #280315
                      mechman48
                        @mechman48
                        When I've regreased bearings in the distant past, if they were 'open ' bearings I used to coat the balls/rollers inner / outer race tracks 'till all was completely coated then put a finger end full of grease in the bottom 1/4 – 1/3rd of ball / roller cage, that was usually sufficient to meet needs. Nowadays majority of bearings are sealed for life behind a metal / polymer / rubber shield so 'old one out new one in'…
                        George
                        #280375
                        Sam Longley 1
                          @samlongley1
                          Posted by Andrew Tinsley on 26/01/2017 14:16:55:
                          I may stand to be corrected here & you my be perfectly right, but grease does not go "Thin" when hot. So I would suggest that if grease is being expelled it is initially due to too much in the bearing. This is what is making the bearing hot which cannot be good for the bearing if over expansion occurs. Agreed some bearings may be designed to run at a certain high temperature.
                          Re " runny" grease I wanted some " thin " grease so I put some high speed machine grease from one of my moulding machines ( forget the grade) on a tin lid & held it over a blow lamp. Nothing changed as far as the grease was concerned. It certainly did not thin out. This is not conclusive of course but does suggest that general machine grease would stay at a consistent consistency
                          #280411
                          mgnbuk
                            @mgnbuk
                            Taper roller bearings behave differently to ball bearings where grease is concerned – ball bearings "churn" excess grease & this generates heat, whereas taper roller bearings have a "pumping" action that moves grease though the bearing & expels the excess. IIRC the grease is moved from the large end of the rollers to the small end.
                            SKF don't recommend using moly or other additives in grease for bearings, just normal lithium soap grease.
                            Nigel B
                            #280568
                            Andrew Tinsley
                              @andrewtinsley63637
                              I have found from experience that Lithium grease does lose a lot of viscosity when hot. I am not certain about other types of grease. However lithium based grease can do this. I have even opened cans that have got very warm in summer and found a liquid on the surface. I am not sure it is supposed to do this, but several different cans have shown this effect over the years!
                              Maybe an experienced lubrication engineer can comment on this?
                              Andrew.
                              Edited By Andrew Tinsley on 27/01/2017 14:28:00
                              #280728
                                Taper roller bearings in an ML10 headstock are nothing special. They are just the same as the wheel bearings on millions of cars and trucks around the world. Any wheelbearing grease from a car parts store will do the job more than adequately.
                                +1 on don't pump grease in until you see it come out around the spindle. It can ruin the bearings and serves no good purpose whatsoever. That's why the manufacturers tell you not to do it. I've seen it done on a set of HVAC blower fan bearings on a 4-inch diamter shaft where the engineer in charge insisted on pumping the pillow block full of grease once a month until grease came out around the felt seals. They had to replace the bearings every six months or so and could not work out why. Looking for stray electrical currents, dynamically balancing the impeller etc and even increasing the greasing schedule to weekly!. Normally such bearings have 25 to 50 per cent grease fill in the pillow block and last for years and years and years.
                                Clive's suggestion of one pump of the grease gun every 10 hours' runtime would be about right, if not a bit on the over-lubed side.
                                If you are in any doubt, open up a brand new sealed bearing and you will find the tiniest skerrick of grease in there, a mere smear. They run for decades like that. Look at how many 20 year old cars still have the original sealed alternator bearings running just fine.
                                Edited By Hopper on 28/01/2017 02:30:37
                                Edited By Hopper on 28/01/2017 02:31:59
                                Edited By Hopper on 28/01/2017 02:32:47
                                #280773
                                Andrew Tinsley
                                  @andrewtinsley63637
                                  Hello Hopper,
                                  I don't mind in the least at being pulled up for duff information. The problem I have got, is that a lot of the advice appears to be somewhat conflicting. As I said before, there is no way I know of, to determine how much grease there is in an ML10 bearing, So whatever you put in, is pure guesswork. You go on to say, quite rightly, that there are thousands of cars that run for many years with a sealed bearing in the alternator. Is the implication that it is fine to do the same for the ML10 bearing? As to frequency of greasing, if I adhered to the one shot every 10 hours, from my Wanner, then I would rapidly fill up the bearing, which is precisely what you counsel against. I do bow to better knowledge and will not in future fill up the bearings until grease comes out, I am guilty of bad practice.
                                  I am still very curious as to the behaviour of lithium grease. There is no doubt that under very hot summer conditions, in a shed, the grease appears to start melting and there is liquid in the can. I assumed wrongly, that if I overfilled the bearing, then it would self correct, by melting out. I have seen this "melting" behaviour with various makes of lithium grease, but never with any other type. Maybe what I am seeing is not due to a melting process. Does anyone know what is going on here and has anyone else ever seen this curious behaviour?
                                  Thanks,
                                  Andrew.
                                  #280818
                                  mgnbuk
                                    @mgnbuk
                                    And how many vehicle alternators use taper roller bearings ?
                                    You are comparing apples & pears here – vehicle wheel bearings these days are sealed for life angluar contact ball bearings, alternators are ball bearings, many plummer blocks are ball bearings – as I said earlier, over greasing ball bearings is not a good idea. But taper roller bearings work a little differently – well, that is what the Timken Design manual said when I had to consult it for the design of a machine tool spindle bearing arrangement some years ago. I don't have access to that manual any more, but do recall the comments about taper roller bearings having a "pumping" action on the lubricant & I believe that is the reason for recommending a periodic regreasing on taper roller bearings that may not be required on ball bearings.
                                    Nigel B
                                    #280821
                                    Clive Hartland
                                      @clivehartland94829
                                      Just to confound you all, I will quote from the hand book of the ML10 and this also applies to the Speed 10.
                                      Headstock bearings front and rear taper rollor brg, Lubricate every 4 to 6 months with Lithium grease until it oozes out of the bearing.. This on page 6 of the hand book.
                                      #280823
                                      David Jupp
                                        @davidjupp51506
                                        Posted by Andrew Tinsley on 27/01/2017 13:26:49:
                                        Andrew.
                                        The phenomenon you have observed is 'static bleed' where some of the base oil is released by the thickening agents. This and 'dynamic bleed' – which can cause problems in bearings are explained nicely in this article…
                                        Andrew Tinsley
                                          @andrewtinsley63637
                                          Thank you David!
                                          That seems to explain what I have seen with lithium grease. Thank goodness there is a rational explanation for the phenomena!
                                          Clive,
                                          That will put the cat amongst the pigeons! So the manufacturers seem to care not how much the lathe is used in a 6 month period! Also they don't seem to mind if the grease oozes out.
                                          Maybe the answer is that it doesn't really matter what you do as long as you occasionally remember to grease the little perishers. But stop when you see movement, otherwise you get a very greasy belt! Come to think, maybe I should read the manufacturers handbook, no excuse here as I do have it!
                                          As to the front bearing, God only knows how you see grease oozing out of that one, as it is completely shrouded from prying eyes!
                                          Thanks all for an interesting discussion, at least I now know why you get the liquid formation in the lithium grease.
                                          Thanks again,
                                          Andrew.
                                          #280939
                                            Posted by Andrew Tinsley on 28/01/2017 10:52:43:
                                            Hello Hopper,… You go on to say, quite rightly, that there are thousands of cars that run for many years with a sealed bearing in the alternator. Is the implication that it is fine to do the same for the ML10 bearing?
                                            No. The implication in this convenient example is that roller and ball bearings in general do not need to be packed full of large amounts of grease in order to function correctly and last for many years. They are rolling elements and need very minimal lubrication.
                                            Edited By Hopper on 29/01/2017 02:05:19
                                            #280940
                                              Posted by Clive Hartland on 28/01/2017 14:21:58:
                                              LOL, when all else fails, read the destructions.
                                              Thinking about it further, it would seem there must be no proper seals on the ML10 bearings if grease can ooze out. (I'm not familiar with the ML10). So a) filling the bearings full of grease will not result in damaging pressure building up inside, the grease being free to ooze out in  best British engineering tradition. And  b) pumping grease in will flush out swarf and dirt that has gotten into the bearings due to the el cheapo lack of seals on the bearings. Just like on the Myford rubbish felt bed wiper system made up for by flushing out with the oil gun.
                                              But in this day and age, wouldn't synthetic grease work better than lithium?
                                              Edited By Hopper on 29/01/2017 02:00:59
                                              #280966
                                              Clive Hartland
                                                @clivehartland94829
                                                Be careful with synthetic greases as they cause , 'Skipping' of ball and roller bearings the balls and rollers do need a tad of resistance to roll properly and I have read of premature bearing failure by use of synthetic low friction stuff. Traditional is best it seems.
                                                It is easy to think that filling a bearings void volume with grease is the way, but in my trade on some tiny bearings I had to apply lube with a hypodermic syringe, a miniscule dot of oil otherwise it affected the performance of the instrument. Ask a Watch repairer how much oil on a spindle, very little and dont get it on a hairspring.
                                                #281150
                                                Andrew Tinsley
                                                  @andrewtinsley63637
                                                  No one seems to have taken the point that you cannot see what the greasing level is in the ML10 bearings. So it makes sense to let the grease come out, at least you know the amount you have got in there!
                                                  As to good old British tradition of letting grease out to purge the lubricant in the bearings. Sounds a damn good idea to me. My friends big Chinese lathe has far worse system than that!
                                                  Andrew.
                                                  #281170
                                                    Posted by Andrew Tinsley on 29/01/2017 22:48:14:
                                                    Andrew.
                                                    The point is if you put one or maybe two squirts of grease into a completely empty bearing, that is enough grease to lubricate the bearing.
                                                    I was thinking more in the traditional lines of drip lubricators on plain bearings that then puke all over the lathe, and my Norton "Patented Oil Bath" primary drive system.wink
                                                    #281685
                                                    Steve Langford
                                                      @stevelangford34603
                                                      Hi folks,
                                                      Many thanks to everyone who replied – clearly not just me that's confused!
                                                      In the end, I figured I'd go with the manual's method – squeeze it in until it comes out. The sludge that came out made me glad I did it. My bearings now have no choice but to be full of grease, but the lathe still runs fine – worst that can happen really is that a bit more grease will come out!
                                                      For anyone attempting the same operation in future, a grease gun isn't actually needed – instead, I unscrewed the grease nipples, inserted a syringe full of grease and squeezed that in. Took about 20ml grease before the fresh grease was coming out of the bearing covers. For the rear bearing, it's easy to see the cover and wipe the grease away once you've taken the changegear cover off. For the front bearing, best to take the chuck/backplate off, otherwise you won't be able to wipe the old grease off.
                                                      Again, many thanks to everyone for the wealth of info provided!
                                                      Steve
