Clarke CBS45MD Bandsaw problem
Home › Forums › Beginners questions › Clarke CBS45MD Bandsaw problem
  • #279650
    petro1head
      @petro1head
      Someone very kindly game me this bandsaw
      The problem is I push the on switch but it will not stay on, well it did once. The switch is a contact relay and I suspect there may be a problem with the latching of the relay.
      The relay is like this one –
      Edited By petro1head on 23/01/2017 13:21:01
      #8519
      petro1head
        @petro1head
        #279655
        Jon Gibbs
          @jongibbs59756
          The KJD6 NVR switch is a standard item.
          Just buy another one and fit it and you're job's a good'en.
          HTH
          Jon
          #279656
          petro1head
            @petro1head
            Being a curious type of fella I took it apart and cleaned the contacts, now fixed
            #279661
            richardandtracy
              @richardandtracy
              I have a question: Does yours automatically switch off when it has cut through the work?
              I have never been able to get a setting on the switch poker that actually switches the switch off when the arm drops after finishing cutting the work. I think the rubber over the buttons on mine is too stiff and doesn't allow the button to be pressed fully.
              Richard.
