have 4:1 from 3000rpm dropping down to 750 rpm what gears to get 600rpm
Home › Forums › Beginners questions › have 4:1 from 3000rpm dropping down to 750 rpm what gears to get 600rpm
Viewing 25 posts - 1 through 25 (of 53 total)
  • #245023
    Martin Newbold
      @martinnewbold
      Hi am wondering what intermediate pulley size to use in above to get to 600rpm please with three pulleys or four one extra of 1"
      #8197
      Martin Newbold
        @martinnewbold
        #245025
        Martin Newbold
          @martinnewbold
          My pulleys are 4" 1" and 1" what would other pulley be to deliver as near to 600 rpm from 3000 I can get please?
          Cheers
          Martin
          #245028
          Martin Newbold
            @martinnewbold
            Hello
            Ah I see from the 750 rpm I need a driven 5" pulley driving a 4" on the final from my 1" on motor driving 4" So would need a 5" and a 4", on single intermediate shaft.
            Cheers
            Martin
            #245031
            Les Jones 1
              @lesjones1
              A 1" pullely driving a 4" pulley will give a 4 to 1 reduction. If they are V belt pulleys then you need to know the effective diameter. You do net get the correct ratio measuring the outer diameter or the diameter of the bottom of the groove. I have never seen a V belt pulley as small as 1"
              Les.
              #245075
              Ajohnw
                @ajohnw51620
                Posted by Les Jones 1 on 01/07/2016 21:46:41:
                Les.
                You will probably find the info you need in a belt drive manufacturers catalogue. Some make belts and pulleys.
                Mark C
                  @markc
                  Martin,
                  1 in pulley on motor driving 4 inch on lay shaft with a 1 inch driving a 1.25 inch on the driven shaft.
                  So, 1"->4"/1"->1.25"
                  You will need a small section belt, 1 inch is a bit small even for a z section belt I think. If you need accurate speed reduction, positive drive is required – belts "always" slip and change ratio as they wear…..
                  Mark
                  #245107
                  John Hinkley
                    @johnhinkley26699
                    I'm somewhat confused by your query. In the title you say you want to know gearing to achieve the reduction, then in the body of the text, you mention pulleys. You simply want a combination which will give you a reduction ratio of 5:1. Using one intermediate gear in a gear train will not affect the overall ratio at all. Without knowing the application, it's difficult to recommend a suitable combination, but if one pulley is only 1" diameter, I suspect that you're probably going to have to go to a toothed belt/pulley set-up. A quick look on the Beltingonline web site indicates mega-money for a 12 tooth/60 tooth combo to accept a 25mm wide belt. Depends how much power you need to transmit, too. You could possibly make do with a narrower belt if, as I suspect, the power transmission is fairly low. For example, I get away with a 10mm wide belt on my toolpost spindle, but that is powered by a 90W sewing machine motor.
                    Others may have a different interpretation.
                    Martin Newbold
                      @martinnewbold
                      Sorry to confuse you jon . It would not let me edit the title to change it to a pulley I am measuring the inside of my pulleys in the narrowest section is this wrong?
                      #245139
                        If you use poly-v you can use a 3/4" on the motor and a 3 1/4" pulley on the drive.
                          I'd come at this problem from another direction, that is how to get useful speeds from the ratios provided by a standard step pulley set. The advantage of using a step pulley pair is that only one belt is needed to change speed, with the drive-shafts arranged so that the belt is also a standard size.
                          For example a pair of these with 2", 3" , 4" and 5" diameters would give you:
                          3000 rpm x 2" / 5" = 1200 rpm
                          3000 x 3" / 4" = 2250
                          3000 x 4" / 3" = 4000
                          3000 x 5" / 2" = 7500
                          As these ratios driven direct from a 3000 rpm motor are far too fast, the motor should be geared down first with a fixed ratio pulley or gear pair. Of these:
                          2:1 in front of the step pulleys would give you 600, 1125, 2000 and 3750 rpm
                          3:1 would give you 400, 750, 1333 and 2500
                          4:1 would give you 300, 562, 1000 and 1875 rpm – this starts to feel reasonable for your Drummond
                          5:1 might be better with: 240, 450, 800 and 1500 rpm.
                          6:1 gives 200, 375, 666 and 1250
                          Hope I got the maths right and that this makes sense!
                          Cheers,
                          Keith Long
                            @keithlong89920
                            Martin – have a look at the following web-page – http://www.gizmology.net/pulleysbelts.htm – on that you'll see that for a V belt the pitch line is fairly close to – but not the same as the outside of the belt. Have a look at the Gates belt website as well. There are belt calculators on there that you can run on-line and when you put in the information about your drive it will tell you what belts are suitable as well as working out centre distance, ratio etc.
                            It looks as though your lathe only has a single pulley on the spindle – if so that will limit what you can do as you need to alter the spindle rpm to suit the job in hand. The speed that you're trying to get is pretty much the maximum that your lathe will stand. The lathe when Drummond built it would have had 3 different diameter pulleys on it, driven from 3 pulleys on the treadle. Drummond's recommended speed for the counter-shaft for a A type (round bed) is 250 rpm with the cone pulleys on that and the lathe spindle giving spindle speeds of 125, 250 and 500 rpm. If you are now looking at installing a counter-shaft then see if you can get a speed change facility through that as without it you'll be limiting yourself to the work that the lathe can cope with.
                            #245172
                            Martin Newbold
                              @martinnewbold
                              Oh dear this is getting confusing . I have 3 pulleys on my Drummond 3b not a round bed am using the top one which i thought to be a 4" inside and 4.5" outside. The belt runs on the brim of this as its a round profile.
                              The motor has also there pulleys I am in smallest with 1" inside and 2" outside this runs well in the v shape
                              I have a 3000rpm motor and used which is a really good site .
                              rpm for lathe
                              This said it should be running 750 . So if i use two indermediate gears with 5" as drive to 4" on lathe and 4" to my motor will this not give me 600? I understand this is the correct rpm
                              Using this again to derive the final speed from 750rpm
                              Edited By Martin Newbold on 02/07/2016 19:37:45
                              Edited By Martin Newbold on 02/07/2016 19:44:51
                              #245178
                                Hi Martin,
                                Yes if you mean this way
                                Edit
                                Whoops I got the diagram wrong.  Will try again in a minute!
                                Edited By SillyOldDuffer on 02/07/2016 20:46:17
                                #245180
                                  Hi Martin,
                                  Second attempt to get the diagram right!
                                  Cheers,
                                  Martin Newbold
                                    @martinnewbold
                                    No Dave , your diagrams not right middle should be 4 and 5 and bottom 4. is what i thought from my pages and post above.
                                    So 1 to 4 sharing spindle  5 to 5
                                    Cheers
                                    Martin
                                    Edited By Martin Newbold on 02/07/2016 21:48:05
                                    #245189
                                    Martin Newbold
                                      @martinnewbold
                                      Actually i think you are right Dave but this is not going to work for me as have 4 on lathe and 1 on motor
                                      #245191
                                        Just get a motor speed controller? Fit a RPM indicator (a fiver, or so, from epay). Then choose any speed you fancy.
                                        Questions might be ' Why 600rpm?' 'What tolerance?' 'What type of prime mover?' 'AC or DC, if electric, and brushed or brushless?' 'What space restrictions?' Etc.
                                        As mentioned, V belts do not drive on the bottom of the groove. Only flat belts do that! Washing machine motors, working with multi v belts, can have a huge speed reduction in one go.
                                        Yes, it may be easier , and possibly cheaper, to control the motor speed….
                                        Edited By not done it yet on 02/07/2016 23:36:44
                                        #245209
                                        Martin Newbold
                                          @martinnewbold
                                          Hi Notdoneityet
                                          I had a feeling I rang some kind person who had a website about Drummond's an I think Tony said mine should run at 600rpm i think. But this was a while ago and much has happened . Speed controller from ebay do you have a link please
                                          Cheers
                                          Martin
                                          Edited By Martin Newbold on 03/07/2016 09:14:45
                                          #245213
                                          Ajohnw
                                            @ajohnw51620
                                            Your web calculator is only approximate. To be exact it would need to know what the belt profile was. There are several of these.
                                            It's generally not a good idea to use a pulley as small as 1" dia to transmit power so just how feasible that is depended on the power of the motor you have and the belt profile you are using.
                                            In order to use a speed controller the motor would need to be a brushed type or 3 phase driven from an inverter.
                                            Tony probably said 600 rpm as the whole area is a little to difficult to go into over the phone. For a one speed lathe it's not a bad choice but a range of say 250, 500 and 1000 along the lines of what Dave suggested would be a lot better. Your Drummond very probably did use a speed reduction from the motor to a counter shaft and then pulleys on that and the spindle to set the speed. Some use a pair of pulleys on the motor to counter shaft drive to obtain more speed.
                                            If you want to do the speed reduction in one step Neil's poly V suggestion will probably work out with a small pulley in the size you are contemplating on the motor up to circa 1/3 hp / 250w output motor but the belt will need to be pretty tight and 5 to 1 via a 1" pulley is still a bit extreme for these as there wont be much belt lap round the small pulley. If it was a 1400rpm motor which is what is usually used on belt drive lathes this would be lot less of a problem.
                                            Gordon W
                                              @gordonw
                                              I may be reading this all wrong-but. If you want to gear down a motor to run a lathe the exact speed is not important, measuring V pullies on the outside will be near enough, it is a ratio so both errors will be similar. Small dias. not good, but if you must then use a jockey pulley to give more wrap on the small pulley. Multi-vee belts are the way to go for small pullies.
                                              #245218
                                                It's a lathe not a record player. The correct speeds for an old Drummond are Fastish, Slowish, and Something inbetween. Have a look at typical lathe pictures and you see the small motor pulley drives a big pulley on the countershaft. The biggest you commonly see on ebay is 6 or 7 inches so get that but as your motor is twice as fast as usual you might want to find the biggest you can. (mine is 8in)
                                                Then on the countershaft put a step pulley similar to the one on the spindle, or smaller. You can make this out of wood to experiment. (mine goes 1&1/2 to 3&1/2).
                                                Meanwhile look for a 1425 rpm motor.
                                                #245228
                                                Ajohnw
                                                  @ajohnw51620
                                                  Posted by Gordon W on 03/07/2016 10:14:16:
                                                  Jockey pulleys don't always help – the linear distance of belt contact around the pulley is the important aspect. The actual contact area can only transmit so much power without slipping. This effectively means that for some power level there is a minimum pulleys size what ever type of belt it is, some types being more capable than others.
                                                  Edited By Ajohnw on 03/07/2016 11:17:34
                                                  #245241
                                                  Ian S C
                                                    @iansc
                                                    You don't say which motor type you are going to use, but if it is a single phase two pole induction motor, it's theoretic speed is 3000rpm, it's actual speed will be about 2850rpm, at that speed the ratio you require is 4.75:1 to give the 600rpm you want. Ian S
                                                    Edited By Ian S C on 03/07/2016 12:34:49
                                                    #245242
                                                    Ian S C
                                                      @iansc
                                                      double post
                                                      Edited By Ian S C on 03/07/2016 12:37:41
