Hi all,
I went to use my Drummond M Treadle Lathe for the first time today and had quite a bit of trouble. I am not sure of it is user error, tool problems or if I am asking too much of the lathe. My first project is a aluminium pulley, 2" in diameter and 1" in thickness. I have a aluminium round bar, about 2 1/2" in diameter, I went to cut a slice off using a hacksaw, but the blade was a little blunt so I decided to try and part it off instead. I got the bar set nicely in the lathe, supported on one end using the dead centre.
However, when trying to part off I kept having problems, with the lathe being really hard to turn, stopping and the belt coming off or the lathe simply taking insignificant amounts off. I tried both back gear and mid-pulley, but after 1 1/2hrs of hard effort on the treadle I had only gone in about 7mm! The parting off tool is 3/16th in width and I used paraffin as a cutting fluid.
I have made a very short video off my efforts:
Am I asking too much of the lathe? If so this might not be the lathe for me… If it's just me getting it wrong that's great, I hopefully can fix that.
Thoughts and suggestions very welcome!
Thanks,
James
Edited By James Jenkins 1 on 29/06/2016 22:02:10
Edited By Neil Wyatt on 29/06/2016 22:27:43
