It's a cheap simple lock, usually easy to pick. You need a tension wrench to provide light torque while giving the pins a jiggle about, the stainless steel strip found in car windscreen wipers makes good tension wrenches though a screwdriver or similar can be pressed into service, lockpicks are typically made from steel shimstock, 25thou to 15thou being a workable range, a single triangle toothed shape to "rake" back and forth would most likely get you into this one.
Loads of videos on youtube, try a search for the lockpickinglawyer for some quality inspiration.
I have picked similar desk drawer locks using paperclips, though I wouldn't recommed that as it is fairly tricky due to the lack of tool strength.
Edited By Cabinet Enforcer on 02/09/2020 12:56:03
