Cutting a large chunk of nice aluminium into workable pieces
Home Forums Help and Assistance! (Offered or Wanted) Cutting a large chunk of nice aluminium into workable pieces
  • #33349
    Danny M2Z
      @dannym2z
      #391959
      Danny M2Z
        @dannym2z
        A friend who works at a large engineering workshop did me a great favour,
        For an $18 (Au) 'donation' to the brew club this 'offcut' duly arrived.
        It's 20mm thick and harder than a witches t**s so my problem is how to cut it into practical sizes to fit into my X-3 mini-lathe and X2 Mill.
        I am not looking forward to 'hacksaw solutions' but maybe the only way so it's going to be a pita although the exercise should do me well.
        46° (about 117°F) here on Thursday, too hot to work in the den btw.
        Any comments and tips about the machinability of this aluminium are most welcome.
        * Danny M *
        #391960
        Thor 🇳🇴
          @thor
          Lucky you. A friend got a similar thickness off-cut of marine aluminium alloy and we used an angle grinder with an abrasive disk intended for use on aluminium and its alloys. A few cuts were made using a hacksaw, we had less than half your temperature though. I have used a chunk of it to make a housing for a small turbine I'm working on.
          Thor
          #391961
          Sam Longley 1
            @samlongley1
            First you need to decide what you want to make with the pieces.
            It would be silly to cut it up & then find that you needed a manhole cover that sizesad
            then a thin abrasive blade in an angle grinder perhaps?
            Edited By Sam Longley 1 on 20/01/2019 06:49:52
            #391962
              Vertical bandsaw
              You could always use say a 5mm dia cutter as the short length looks like it will be within the X3s x-axis travel and cut half way from each side.
              #391972
                For info. **LINK**
                http://www.aalco.co.uk/datasheets/Aluminium-Alloy-5083-0-H111-Sheet-and-Plate_149.ashx
                Some excellent characteristics yes
                … concluding with 'Machinability poor' sad
                Additional, on the difference between H111 and H112
                http://referansmetal.com/alasimli-aluminyum/product/339/en-aw-almg4-5mn0-7-5083-h112?lang=en
                Edited By Michael Gilligan on 20/01/2019 08:21:41
                #391983
                Chris Evans 6
                  @chrisevans6
                  5083 should not be that tough, does the donor mates workplace have a bandsaw? They may cut it for another few dollars and save the sweat.
                  #391989
                  Involute Curve
                    @involutecurve
                    I often cut 5083, 50mm thick on my bandsaw quite easily, its great stuff especially for welded parts as it retains its strength after welding unlike 6082 which requires heat treatment after welding in order to return to full strength.
                    Shaun
                    #392100
                    Danny M2Z
                      @dannym2z
                      Thanks for all the info people and especially the links from Michael Gilligan.
                      #1 G/F has a large vertical bandsaw in her workshop so I might ask about fitting a suitable blade and leaving it behind as payment.
                      I only want a few small slices to experiment with to see how it machines into model engine con-rods and compare it with the 2024 T3 that I currently use.
                      * Danny M *
                      Edited By Danny M2Z on 20/01/2019 18:23:22
                      #392106
                      John Reese
                        @johnreese12848
                        I would use my tablesaw. I have a non-ferrous blade of triple chip design that works well. I have also cut aluminum with a hand held circular saw.. Either way listen to the saw motor. If it starts to pull down, feed more slowly. On the table saw chips flew everywhere. I put a cardboard box, open side down, over the work to contain the chips. If you have any electrical cords plugged i make sure theyare inserted fully into the receptacle. A fine piece of aluminum floating down onto the exposed prongs of a plug can get pretty exciting.
                        #392111
                          Posted by Danny M2Z on 20/01/2019 18:22:44:
                          Lop off a corner for minimum cutting and leaving the most useful large piece behind.
                          Vic
                            @vic
                            They used to cut alloy plate up to 2” thick on a vertical bandsaw where I used to work. It took ages mind and several people for the bigger bits.
                            #392123
                            Dalboy
                              @dalboy
                              I have a piece of Ali sheet that is approx 1-meter square and 3mm thick I have left it as a complete piece as I do not know what to do with it and the minute I decided to cut it up it will end up being too small so will cut when needed. I do the same with wood always leave it whatever size I get it until needed then cut.
                              #392191
                              Ian S C
                                @iansc
                                As part of an article in ME about building an open crank engine, the builder obtained a large billet of aluminium, he needed to cut it up, so built a power hacksaw, I think there may have been a bit about it's construction.
                                Ian S C
                                #392192
                                Mike Poole
                                  @mikepoole82104
                                  Always leave your wood as long as you can for as long as you can.
                                  #392312
                                  The Novice Engineer
                                    @thenoviceengineer
                                    I successfully cut some 20mm Al plate on my Draper 350 Band Saw [this is NOT a dedicated metal cutting band saw] with a 6TPI blade, it helps to have a vacuum cleaner to suck up the chips
                                    I also like to clean up any chips that get in side on to the rubber tyres before they get embedded.
                                    Edited By The Novice Engineer on 21/01/2019 23:01:21
