NVR Switch
NVR Switch
Home Forums General Questions NVR Switch
Viewing 25 posts - 1 through 25 (of 28 total)
  • #569706
    Lynne
      @lynne
      Good evening, The lathe forward/reverse NVR switch latches when forward is
      selected, but not in reverse. What is the likely reason for this, and can it be
      fixed' Thanks, Lynne
      #28423
      Lynne
        @lynne
        #569714
        Emgee
          @emgee
          Hi Lynne
          If it has never worked correctly it could be wrong connections in the fwd/rev switch, is the NVR switch fitted in the line from the fwd/rev before it goes to the motor or starter if you have one fitted.?
          Emgee
          #569730
            If it any help, My Mill came with the NVR switch wired between the mains input and the Forward / Reverse Switch.
            That is the way that i would prefer it anyway, to make things simple. The mains supply then just goes to the Fwd / Rev without any complication.
            #569746
            Oven Man
              @ovenman
              Is the NVR and reverse switch an integrated unit or are they two separate switches? I have never come across an integrated unit. Normally the NVR is on the mains input and the forward/reverse switch is on the output from the control board and just swaps over the positive and negative lines. So changing direction should have no impact on the NVR switch.
              Peter
              #569749
              Frances IoM
                @francesiom58905
                often the forward/reverse switch has a centre position to force power off – if the reverse section of this power switch is faulty then might explain it.
                #569750
                noel shelley
                  @noelshelley55608
                  What sort of Lathe ? What Sort of motor ? AC or DC brush or brushless ! NVR MUST be before the reverse switch ! Has this just happened ? what sort of Forward and reverse switch do you have ? As always pictures will be a big help ! Noel
                  #569752
                  Clive Foster
                    @clivefoster55965
                    The inexpensive units generally found on import tools are, as Oven Man says, almost invariably integrated with the forward – reverse selector after the NVR system. Select direction then turn on with the NVR unit. Usually the direction selector is under a cover.
                    For example :-
                    **LINK** https://www.chestermachinetools.com/product/electrical-n-v-r-switch-415v/
                    I dislike those because the direction selector is hidden and has no clear indication of which way the machine will run when started. The NVR unit often used to only operate on one line too, the live feed. Which is sort of OK if all is wired correctly but is neutral and live are interchanged! Hopefully current versions operate on both but ….
                    If the NVR isn't latching in one direction either a wire is off or something is broken. Early ones were very confusing to install and it was possible to connect with NVR latching only on one direction. I suspect the one I played with was made that way so you could have a "jog" reverse to back off a jam rather than free running. If yours is like that one sorting without a wiring diagram will be a headache.
                    The real industrial rated thing has separte mechanically interlocked contactorsto give NVR functions both ways.
                    You use this
                    **LINK** https://www.shutterbits.co.uk/3-way-push-button-station-288-p.asp
                    with this
                    **LINK** https://uk.rs-online.com/web/p/contactors/0758793
                    (pretty much what I have in stock to operate my American style bifold garage door when I finally get fed up with the temporary winch.)
                    Edited By Clive Foster on 04/11/2021 10:28:09
                    #569757
                      The symptoms suggest to me that the forward/reverse switch has failed. Either the Reverse contacts have broken, or maybe a wire has vibrated loose and broken the reverse connection.
                      On my machines the switches have always been mounted on front panels that can be unscrewed and lifted off to see the wiring or change the switch. A dangling connector should be obvious, and is generally an easy fix. Otherwise, the F/R switch can be replaced : they're not difficult to source. A photo would help identify it.
                      Which machine is it? Someone might have a circuit diagram.
                      Oven Man
                        @ovenman
                        The big question here is what type of motor is it, AC or DC?
                        I guess the Chester integrated unit referred to above is for single phase AC motors with switched (centrifugal) start winding and run winding, the modern equivilent of an NVR and Dewhurst switch.
                        Peter
                        #569761
                        Clive Foster
                          @clivefoster55965
                          SOD
                          The OP implies that the machine still runs in reverse but the NVR doesn't latch so the start button has to be held down for it to run.
                          This suggests that the forward reverse switch itself is sound but there is no power being supplied to the NVR coil in reverse. So, as I suggested in my previous post, reverse is operating in jog mode.
                          Connection issue with the NVR unit either internally or, if it is intended to have a jog mode connection, externally.
                          Assuming its one of the inexpensive import NVR units similar to the one I linked to above, best to simply change the unit if its not an obvious external connection failure.
                          Personally I'd swop for an industrial rated system like that in my second links. The interlocked contactors can be found more cheaply. Think I paid around £40 for mine and £15 (ish) for the button box. Roughly double what a the common import unit costs so not scary out or reach.
                          But I dislike the compromises often inherent in affordable equipment and can afford to indulge that affectation. Which many folk can't.
                          #569766
                          Dave Halford
                            @davehalford22513
                            Hi Lynne,
                            By 'the lathe' I take it you mean your ML7B in your photo album. So you should have the NVR as your motor on/off contactor, then the forward/reverse switch, then the motor.
                            It sound like the NVR is in the wrong place.
                            #569767
                            Lynne
                              @lynne
                              Thanks for the responses. Let me try to clarify things. The switch is an integrated unit, made by Kraus & Naimer,
                              and was a factory fit by Myfords, when Myfords was Myfords,so I guess that means its getting on in years, a bit like me. It is operating on mains AC, and has operated fine for years, and it is only recently that it has started not to latch when selecting reverse. This is an intermittent fault, as this morning it held ok. The selector is mounted on the top of the unit, not shrouded. I will take some pictures, but it may be a while before I get them up here,
                              Regards Lynne
                              #569771
                              Clive Foster
                                @clivefoster55965
                                Lynne
                                Sounds like it could well be a proper industrial type unit with mechanically interlinked forward-reverse contactor pair inside somewhat like that in the final link of my first post.
                                If so the problem could well be wear, adjustment or simply gunge issues in the mechanical interlock. The interlock basically protects against selecting forward and reverse at the same time. If the travel on one, or both, sides is limited for any reason it will prevent latching by inhibiting the coil "keep alive when running circuit" on that side.
                                #569814
                                Brian Morehen
                                  @brianmorehen85290
                                  We know now this is Myford Lathe My thoughts are that some contacs in the NVR control are either worn or require cleaning also is this working on 3 phase or single phase . Lack of info is giving rise to a load of unneded answers.
                                  More Info Please
                                  Bee M
                                  #569913
                                  Lynne
                                    @lynne
                                    good morning, Thanks for all your responses. I have opened the unit,& as the switch/coil is an intergrated assy, I am not inclined to dismantle further. I will live with it as it is. I did contact Kraus & Naimer uk, & they say they are not aware of a stockist, as it is a power failure release switch which are direct from the factory, & which to me sounds expensive.
                                    BeeM. May be you have'nt picked up on my post @ 12:27:23.
                                    I have put some pictures of the switch into the album. Regards Lynne
                                    #569918
                                    Emgee
                                      @emgee
                                      The last time I enquired about a price for a similar switch for an Emco Milling machine cost was £94
                                      Is there a part number showing on the switch ? if so a replacement could be sourced.
                                      Emgee
                                      #569933
                                      Brian Morehen
                                        @brianmorehen85290
                                        Yes I did note that your post @ 12;27;23 stated that it does work some times ,, This is why a said that the possibilty was that the contacts in your NVR Contact or the forword and reverse switch may be dirty so causing a poor connection sometimes , If you can get access to these contacts with a small brush and some meths a clean may work together with a puff of air if you have a airline, I used to do a maitenance program on a large laundry which envolved cleaning contactors on 3 phase motors of 25 HP plus which proved a good and reduced breakdowns.
                                        Good Luck
                                        Bee>M
                                        #569941
                                        Dave Halford
                                          @davehalford22513
                                          That switch stack looks fairly open, you could try a blast of compressed air.
                                          #569949
                                          Lynne
                                            @lynne
                                            There is a Pt.No. on the switch, but I think it is going to be difficult to source a replacement, since the UK arm of Kraus & Naimer are not aware of a stockist. I would be reluctant to buy 2nd hand, not knowing how much use it had been subjected to. I would certainly give it a blast if I had compressed air. There are no contacts exposed so meth and a brush are out. Thanks again. Regards Lynne
                                            #569967
                                            Brian Morehen
                                              @brianmorehen85290
                                              If hyou have a Poundland near you you can buy a aerosol Air Duster for £1.00. This is worth a try I use these very often for quickness.
                                              Regards Bee.m
                                              #569976
                                              duncan webster 1
                                                @duncanwebster1
                                                My lathe came with an integral fwd/rev/nvr. I sold it when I upgraded to 3 phase and inverter, but I could scan the wiring diagram if that would help
                                                #570009
                                                Les Jones 1
                                                  @lesjones1
                                                  After looking at the pictures in your album I am not convinced that it is an NVR switch. Start the lathe in the forward direction. Switch the power supply off to the lathe. Did the switch return to the centre off position ? Restore the power to the lathe. Does the motor start as soon as the power was restored ? These tests will show if it is an NVR switch.
                                                  Les.
                                                  #570078
                                                  Nicholas Farr
                                                    @nicholasfarr14254
                                                    Posted by Lynne on 05/11/2021 10:52:56:
                                                    Hi Lynne, I suspect it could be a customized range Kraus & Naimer rather than a stock type. The fault could be a loose connection in the reverse line or a dirty or arced contact in the switch.
                                                    Regards Nick.
                                                    #570112
                                                    Clive Foster
                                                      @clivefoster55965
                                                      Lynne
                                                      A quick Google turns up the official 2021 Krause & Naimer short form data on the cam switch range at **LINK** https://www.krausnaimer.com/fileadmin/user_upload/Kraus_u_Naimer/Pdfcat/KN120GB.pdf .
                                                      From your pictures the switch you have seems to be a standard blue-line cam switch. These things can be built up in myriads of configurations by combining switch blocks, actuating units, control levers and position indication plates. Just a matter of flogging through the various codes for each part to get the device you want. (Headache pills and a wet towel round your head probably essential if starting from scratch.)
                                                      Looking at page 6 it appears that the code for a no volt release actuator is CG8X which mates with an S0 size switch. I see no reason why the actuator can't be ordered as a separate unit and replaced. Having changed switch stacks on a similar unit, albeit without no volt release, on my Bridgeport I can confirm that they come off and go back quite easily. However its unwise to remove the connections as figuring out what goes where can be a problem. I had no choice as mine had been bodged round burnt out contacts!
                                                      If you decide to order a complete unit it seems like you have a double throw switch with 60° switching angle.
                                                      Page 23 shows specific motor reversing switches. Alternatively it could have been built up from switch sets as shown on page 11 where there is a choice of plain centre off or electrically isolated contacts.
                                                      Hopefully the codes on the switch bodies are still visible so ordering a new complete unit shouldn't be too hard.
                                                      But I'd just change the actuator which ought to be part CG8X. Assuming you have an S0 size switch, easily sorted by measuring as its a bit under 2" square.
                                                      Really this is something that the UK agents should be almost instantly aware of. But I didn't find them technically knowledgable in the past. Problem is that, so far as I can see, UK stockists tend to hold build up units in the common varieties rather than getting involved in build to order.
                                                      Assuming a 3 phase motor I think part code CG8XA401 be yours. Have to take it apart to figure out the panel mounting system. Probably 4 hole without the escutcheon plate, yours doesn't look to be standard K&N.
                                                      Hope this helps.
                                                      Edited By Clive Foster on 06/11/2021 13:09:44
