Things to save from a CRT TV being scrapped
Home Forums General Questions Things to save from a CRT TV being scrapped
Viewing 25 posts - 1 through 25 (of 34 total)
  • #254607
    Rainbows
      @rainbows
      Have a big CRT TV sitting in a corner. Before I tear it apart and steal the magnet wire has anyone ever found a use for any of the components inside it?
      #24724
      Rainbows
        @rainbows
        #254610
        John Rudd
          @johnrudd16576
          You could remove the LOPT to use in a Jacob's ladder project…..
          The scan coils will provide a small amount of enamelled cu wire…
          The loudspeaker(s) may be useful?
          #254611
          Thor 🇳🇴
            @thor
            I assume you take care when poking inside, the vacuum might cause an implosion if the CRT tube breaks. In addition to the magnet wire I guess there are speakers inside and may be transformers.
            Thor
            #254613
            Ian Parkin
              @ianparkin39383
              My father always used to warn against CRT's imploding a while ago I disposed of one in a skip and decided to see how easy it was to break it
              It took serious effort with a large stone thrown with much force 5 times as I remember
              Safety procedures were taken I hasten to add
              #254616
              Thor 🇳🇴
                @thor
                Something like this Ian?
                Thor
                #254619
                John Stevenson 1
                  @johnstevenson1
                  Nothing – skip it or you will be falling over the junk for the next twenty years.
                  #254638
                  Alan Jackson
                    @alanjackson47790
                    Probably worth extracting all those old tv programmes before you scrap it. Well on second thoughts probably not because they have still playing been playing them recently
                    #254645
                    john swift 1
                      @johnswift1
                      thor
                      that tube didn't have any intergral implosion protection !
                      it reminds me of the tubes from the 1960's tv's
                      they needed a laminated glass to protect the tube face
                      tubes with intergral implosion protection have a very thick molded face
                      with a metal rim band keeping the edge under tension
                      in colour tubes the leaded glass keeps of the X-rays produced to safe levels
                      with an EHT of 24KV , the electons have enough energy to cause the shadow mask
                      (just behind the phosphor screen) to emit X-rays
                      john
                      #254648
                      Ian Parkin
                        @ianparkin39383
                        Thor the screen that I eventually smashed had glass on the front that was 12mm thick it was a flat screen though I just thought that all CRT were like that that's why they were so heavy
                        #254653
                        Peter Hall
                          @peterhall61789
                          Posted by John Stevenson on 07/09/2016 17:33:44:
                          I have just emptied and vacated a workshop. Those are the wisest words I have seen this year.
                          Pete
                          #254655
                            Back in the 70s my dad regularly had to dispose of CRTs. the basic technique involved having the CRT face down and dropping a brick on the 'neck' (not the front) from about 10 feet up a set of steps so he could easily step back out of the way.
                            Another way was to cover with a heavy 'blanket' (I recall it was some sort of mix of coarse coconut or hair and leather) and tap the bit where the wires went in with an 'ammer.
                            The principle was to try and break the fragile bit without the heavy glass shattering.
                            N.
                            #254657
                            Brian G
                              @briang
                              As a child I saw a TV fall from the back of a Radio Rentals van doing about 25 mph along the High Street, I was amazed that it didn't break the screen, just scratch it, especially after all of my Dad's warnings about never playing in the front room because the television was so fragile.
                              Brian
                              #254660
                                The safe way is to cover it securely and nip off the end of the nipple where it was originaly sealed. If not unlucky, the tube will fill with air withno more than a bit of a hiss. Still need your ppe, mind. Just in case…..
                                #254664
                                martin perman 1
                                  @martinperman1
                                  Many moons ago I worked for a company that sold handling devices, we had to make a gripper to handle tv tubes, the customer said the screens had been discharged and we had had them for weeks, when I moved one I touched the earth point on the back and got a nasty belt so be careful when handling them.
                                  Martin P
                                  #254670
                                  JA
                                    @ja
                                    I don't think there is anything of value in a CRT.
                                    As already mentioned early TVs had a nice sheet of plate glass in front of the screen which was worth keeping. As for the CRT we used to smash them at school, with teacher instructing us (6th form), by standing the CRT face down in an open box and knocking off the plug end of the gun with a weight, about 100g, suspended from the ceiling. Standing with the door of the room containing the CRT almost closed, you released the weight and quickly closed the door. It always worked.
                                    JA
                                    #254685
                                      ISTR from my childhood that those old TVs had a big transformer inside with a big fat wire going to the tube. If you took the metal cover off the transformer and fired it up, then held a screwdriver about six inches away from it, a great fat spark would arc across the gap – all with no ill effects to the boy scientists involved. How we got away with this stuff I still don't know. But lots of fun was had. Those were the days when you could buy bottles of concentrated sulphuric acid at the chemist shop and they were happy to dispense it to a 10 or 11 year old boy, along with potassium nitrate, sulphur etc used to make experimental gunpowder and smoke bombs.
                                      #254687
                                      David Nitchke
                                        @davidnitchke97485
                                        Hi
                                        Some years ago I was training for several weeks in The Sony Trinitron plant in San Diego Ca
                                        "not done it yet 07/09/2016 21:05:44" –has it correct.
                                        Just break the vacuum seal port in the middle of the tube electrical connector. This was often done in the factory when the CRT gun was to be replaced due to a manufacturing defect.
                                        #254688
                                        Ady1
                                          @ady1
                                          Tellys seemed to come in two types when we smashed 'em to bits
                                          Some imploded as soon as the first brick hit them while others needed some serious effort to make them blow up
                                          Calor gas canisters were much more fun
                                          Edited By Ady1 on 08/09/2016 01:50:03
                                          #254689
                                          Thor 🇳🇴
                                            @thor
                                            Yes John,
                                            The video shows how not to do it! And it gives some idea of what might happen if you don't do it correctly. Neil and others have described a much better/safer procedure, and that's how it was done way back.
                                            Thor
                                            #254702
                                            John Haine
                                              @johnhaine32865
                                              It's 4 decades at least since I took a TV set apart, but the only things I ever found of any use were the focusing ring magnets and the deflection coild. The first were great for playing with and would probably find uses in the workshop. The deflection coild were an unreliable source of copper wire since they were potted with lacquer that made it hard to unwind them. All the rest except for the sheet of perspex in front of the tube was junk. Whether newer colour TVs used perm magnets I have no idea and the deflection coild are probably properly potted.
                                              #254705
                                                Posted by David Nitchke on 08/09/2016 01:46:19:
                                                I suspect my Dad preferred the extra safety distance of the remote brick method of doing this
                                                Ian S C
                                                  @iansc
                                                  Particularly if the TV was a valve set there should be a reasonably large mains transformer, I'v stripped the HT windings off a few of these, and rewound the secondary for low voltage to suit what ever I needed. Componants such as bridge diodes can be handy if you are in to building power supplies.
                                                  Ian S C
                                                  #254784
                                                  Georgineer
                                                    @georgineer
                                                    "… Another way was to cover with a heavy 'blanket' (I recall it was some sort of mix of coarse coconut or hair and leather) and tap the bit where the wires went in with an 'ammer.
                                                    The principle was to try and break the fragile bit without the heavy glass shattering."
                                                    We used several layers of sacking. The neck was nicked near the end with the edge of a file before bipping with a nammer. All safe. By the way, if you decide to do it the same way as the idiot in the video, make sure to breathe in a good lungful of the phosphor dust before it settles. Top up your trace elements.
                                                    George
                                                    #254917
                                                    Martin Connelly
                                                      @martinconnelly55370
                                                      Save your back, get someone else to take it awaywink
                                                      Martin
