What is this please?
Home › Forums › General Questions › What is this please?
  • #248392
    Maurice Cox 1
      @mauricecox1
      Can any one identify this pump like devise please? The main body is four inches long, and one inch in diameter. The three lugs suggest that it was mounted in some sort of panel. There is a very strong internal spring pushing up on the plunger, which is normally held down by a small catch. There is no obvious way to get to the inside. It reminds me of the pumps used to pressurise the fuel tanks on early cars. I don't want to bin it in case it can be of use to someone.
      Mauricefunny pump 1.jpgefunny pump 2.jpgfunny pump 3.jpgfunny pump xtra 1.jpgfunny pump xtra 2.jpg
      #24662
      Maurice Cox 1
        @mauricecox1
        #248395
          Some form of oil pump judging by the fact they made oilers for guns see Grace's Guide
          ESS Oiler will get you a few hits on google
          Edited By JasonB on 28/07/2016 20:09:45
          #248396
            Bit more digging and its a motorcycle oil pump by the looks of things
            Better still see the last image
            Edited By JasonB on 28/07/2016 20:24:06
            #248402
            Maurice Cox 1
              @mauricecox1
              Thank you so much Jason; that looks exactly like it. Saved from the scrap bin!
              Regards Maurice
              #248407
              Tim Stevens
                @timstevens64731
                In use, the pump sat in the top of the tank between your knees*. The plunger was spring loaded upwards, and was pushed down by the rider every few miles and certainly at the bottom of a hill. There was a drip regulator and perhaps a glass bowl on the outlet right-angle, and the little catch was to hold the plunger down when you parked outside the bakers so that the assistant could get flour on your undergarments again.
                In your dreams
                *PS, fortunately the effect of the brakes was to produce a faint rubbing noise, nothing else. This was fortunate because of the position of the plunger in relation to aforementioned garments.
                Tim
