Repetition of articles.
Home › Forums › General Questions › Repetition of articles.
Viewing 25 posts - 1 through 25 (of 38 total)
  • #247498
    Paul Barrett
      @paulbarrett57424
      Attn Neil.
      In issue MEW 244 you've published Alan Wains article "A drill for a budget mini drill" .
      Go back 16 months to MEW issue 228 and you will find the same article.??????
      Does that mean Alan gets paid twice?
      #24652
      Paul Barrett
        @paulbarrett57424
        #247500
          He would have done if you hadn't let me know.
          Now he'll come round and duff you up instead.
          John Stevenson 1
            @johnstevenson1
            Good heavens, there is a sense of humour just slightly left of Burton on Trent
            #247515
            nigel jones 5
              @nigeljones5
              there isnt…except if you include ashby…
              #247518
              Frances IoM
                @francesiom58905
                the cheapest approach is merely to find one of the Minicraft series of drills – I have had one for years + bought another smaller version at a rummage sale
                The thread is 8mm x 0.75 – merely cutting off 5mm from plastic housing on the Maplin version of the drill allows the chuck to fit + fully close – if you buy a die then easy to make a fitting eg that for my Perris lathe on a MT0 taper is shown
                The much better Dremel unfortunately is a 9/32 x 40tpi and I havn't seen chucks to fit this (maybe available in the non-metricated USA only ?
                #247525
                doubletop
                  @doubletop
                  You may not be be paying the author again but can we expect subscibers to both editions to get a bit of a rebate? laugh
                  Pete
                  #247527
                    Posted by Doubletop on 22/07/2016 06:55:04:
                    I'm afraid we aren't Absolute Radio with a no-repeat guarantee.
                    Unfortunately must have I omitted to mark the original as used on my spreadsheet, probably because, as this time, I used it when we needed a short article to fill an unexpected gap.
                    #247539
                    MW
                      @mw27036
                      I personally don't like the drill chuck arrangement on these small drills, a collet arrangement is alot sounder for concentricity from a design point of view.
                      Michael W
                      #247540
                      Robbo
                        @robbo
                        Surely the author should get repeat fees?
                        #247541
                        Ady1
                          @ady1
                          That would certainly be the less complicated legal route to follow…
                          #247547
                          Lambton
                            @lambton
                            Pay the man twice as it is not his fault the article has been duplicated and the owners of the magazine have received full payment from the buying public for both magazines.
                            #247550
                              For the record, we don't pay repeat fees; the amount we pay for articles is significantly better than similar publications partially to reflect the fact our agreement includes giving us a licence to republish without further payment.
                              As for an error like this, any other arrangement is a private matter between us and the author.
                              Ian S C
                                @iansc
                                i don't have one, but I think that chucks for Dremels are available in NZ, at least they were when I last looked.
                                Ian S C
                                #247555
                                Frances IoM
                                  @francesiom58905
                                  “a collet arrangement is alot sounder for concentricity from a design point of view” – I agree but the collets as provided with the ‘el cheapo’ maplin drill grip only on about 1mm of drill shank and have very little range – a small chuck is fine after all it is a handheld non-ergonomic tool (the small donor minicraft drill was a much better designed mini pistol drill but had no speed control nor softstart)
                                  #247565
                                  MW
                                    @mw27036
                                    I have a set of proxxon collets which range up to 3.2mm which is ok, i dont think a drill much bigger than that would be appropriate for it's size. They are made of steel, i believe dremel do a similar set made of aluminium.
                                    Michael W
                                    #247570
                                    Nick_G
                                      @nick_g
                                      Posted by Ady1 on 22/07/2016 09:46:31:
                                      Why are some people getting involved in this.? – I would strongly imagine that the T&C's of submitting articles (and photographs) will allow for repeats and multiple use if required. If so that 'legal route' will be pretty much a none starter.
                                      If there IS an issue I would think that the original author himself will be contacting the publishers. – As I said this all depends upon the terms of the original contract and multiple use is a common type for many magazines.
                                      As for cheating the readers.! – It seems it was a very small human mistake for a short article. Bit like turning an extra 10 thou off that bar by mistake. ………….. We have all done it.! wink
                                      Nick smiley
                                      #247577
                                        Posted by Nick_G on 22/07/2016 12:58:47:
                                        Quite so, Nick
                                          I think you have got of lightly Neil, I was expecting a flood of complaints that the text refers to Fig 1 and you have not included Fig one in the regurgitated versionwink 2
                                          It is strange how some people want a refund if something is published twice but I have never seen anyone ask where to send a donation when Neil puts up old articles on the websitedevil
                                          J
                                          #247582
                                            Posted by JasonB on 22/07/2016 13:22:59:
                                            Come to think of it, Jason … I appear to be one of very few people who have even thanked him.
                                              I was surprised that no-one was pleading Terry Aspin's case.
                                              Edited By Neil Wyatt on 22/07/2016 14:07:24
                                              #247588
                                                Posted by Neil Wyatt on 22/07/2016 14:06:56:
                                                Wouldn't dream of it … I didn't much like 'Chuck' the first time round.
                                                KWIL
                                                  @kwil
                                                  Here Here.!
                                                  #247598
                                                  Roderick Jenkins
                                                    @roderickjenkins93242
                                                    Don't listen to the GOGs. Chuck was usually spot on. He also made some interesting engines and his casting books are first class. Definitely worth repeating the cartoons to a new generation and in a different magazine.
                                                    Cheers,
                                                    Rod (another GOG, but not today – I'm on holiday 😂 )
                                                    Edited By Roderick Jenkins on 22/07/2016 15:20:54
                                                    #247601
                                                      I just thought the parting cartoon was apt given some recent postings and that it still hit the mark.
                                                      Note that the 'Hero' has a Super Adept (as did Terry Aspin himself).
