Regrinding cross head screwdriver tips?
Home › Forums › General Questions › Regrinding cross head screwdriver tips?
Viewing 25 posts - 1 through 25 (of 32 total)
  • #244759
    bugbear6502
      @bugbear6502
      I'm primarily a woodworker, but since woodworking tools are made from metal, I end up doing small scale metal work, normally with hand processes.
      I have had great success over the years regrinding lovely old straight blade screwdrivers – it's well worth it, since some of the handles are either comfortable, beautiful or both.
      But I have some car-boot Pozi and Phillips screwdrivers, of very good quality, where the ends are a little burred up, but still with plenty of good metal left.
      I would like to grind these so the tips are near-perfect again.
      My absurd sharpening/grinding jig should hold the required angles to good tolerance
      http://www.woodworkinfo.site88.net/tour.html#sharpening_jig
      Does anyone know the specifications of Pozi and Phillips (size 2 in both, primarily) ?
      BugBear
      Edited By bugbear6502 on 30/06/2016 10:06:24
      Edited By bugbear6502 on 30/06/2016 10:06:53
      #24613
      bugbear6502
        @bugbear6502
        #244761
          You should find detailed descriptions of the shapes in the relevant Patents.
          … Sorry, I'm on the 'bus at present, so can't really do it for you.
          Look on 'espacenet' advanced search:
          Ajohnw
            @ajohnw51620
            It might be worth going for JIS on the Phillips ones. It's a slight modification to reduce the cam out. I have a set and they always come out if it's a difficult screw. I'm not convinced that the socket in the screw is any different but they make a hell of a difference when I am working on microscopes and I hear on other Japanese products. I assume that the design allows them to tighten the screws more or leaves more tolerance on power driver torque settings. That's the trouble with these designs they were never really intended for hand held screw drivers.
            I often feel that a slot head and truly hard hollow ground blade is a lot better as far as screwdrivers are concerned, These days though all tend to be made with air hardening toffee what ever style they are. The correct temper for blades is rather close to the one for cold chisels used for chiselling steel.
            bugbear6502
              @bugbear6502
              I have found the Pozidriv patent; it's US2474994 (A).
              BugBear (off to find Phillips)
              #244765
              bugbear6502
                @bugbear6502
                Philips – US2046839 (A)
                BugBear
                #244766
                MW
                  @mw27036
                  how would you grind the extremely thin cross section on a pozi-drive, just out of curiosity?
                  #244769
                    Carefully!
                    Thank god for hex bitssmiley
                    Edited By JasonB on 30/06/2016 11:21:11
                    #244770
                    MW
                      @mw27036
                      😛 i thought maybe they forged the shape on a die like a drop forge?
                      Michael W
                      #244772
                      bugbear6502
                        @bugbear6502
                        I'm not planning on grinding a "new shape". That would be "quite difficult".
                        I just want to grind-back the prexisting cruciform shape the sharpen up the burred leading edges.
                        As per the red (lipstick?!) on the right picture.
                        BugBear
                        #244773
                        Ady1
                          @ady1
                          I recently got one of those Lidl angle grinders and fitted it to a stand I had previously purchased at Lidl, this gives it good stability when in use. A 1mm stainless cutting disc means that it can do those really fiddly grinding jobs very easily compared to a standard fat grinding stone
                          I've not done a lot on it but I prefer using it for my HSS touch up jobs now
                          #244774
                          Jon Gibbs
                            @jongibbs59756
                            +1 for Jason's comments.
                            I've got magnetic hex socket handles in various lengths and buy new good quality hex bits (Wiha or Wera) when they get worn.
                            #244776
                            bugbear6502
                              @bugbear6502
                              I feel the love for hex bits, and use them a lot (most of the time, TBH)
                              But sometimes, when a screw head is deeply recessed in a hole, a hex bit holder is too large, and you need a simple screwdriver.
                              And a bit of luck at a recent car boor turned up a lovely Spiralux ratchet screwdriver, PZ2, with a burred tip – the primary motivator for this thread.
                              BugBear
                              #244779
                              MW
                                @mw27036
                                Definitely a much more rigid way to tighten things up with a hex or square, little chance of it rounding out/off
                                They've all got their place though, even all the security lock types. Anyone used a lenz spanner before? one of the more unusual ones.
                                Michael W
                                Edited By Michael Walters on 30/06/2016 11:59:25
                                #244780
                                  Bugbear, you can't just regrind those red edges. If you look at the image you posted the thickness of the 4 "lobes" gets thicker dute to them being hollow ground hence the curved surface.
                                  Pozi will be even harder as there is the extra bit of metal between the 4 main lobes
                                  Get youself some long reach hex recess bits for deep screwheads
                                  Michael I meant 1/4" hex bits which you just chuck away when worn and use a new one not hex or Square/Robertson drive
                                  Edited By JasonB on 30/06/2016 12:06:23
                                  #244781
                                  bugbear6502
                                    @bugbear6502
                                    I certainly can't grind them "much".
                                    And I can grind Pozi even less.
                                    But a little may be enough.
                                    BugBear
                                    Edited By bugbear6502 on 30/06/2016 12:03:19
                                    #244782
                                      But then they are shorter and don't fit as far into the screw for a given size bit and you end up risking chewing up the screw.
                                      #244786
                                      MW
                                        @mw27036
                                        oh, i see, kinda like a carbide tip.
                                        Michael W
                                        #244789
                                          I think it would need a larhe dia grinding wheel like this to go between each lobe first and then grind the red areas toi get it back to original size.
                                          Don't you have a hex holder for your Yankee?
                                          I seldom use the Yankee now but it does have the advantage of the battery not going flat so is always in the toolbox if neededwink
                                          #245410
                                            A set of Hex drivers is pretty cheap, so why not just junk the worn ones, and buy a new set?
                                            (They should be at least more accurate than you can regrind them).
                                            Again, the female drivers are pretty cheap, and can certainly be used in a pistol drill, and probably easily modified to fit in a Yankee pump screwdriver.
                                            #245413
                                              No need to modify a holder to fit a Yankee as you can buy then ready to fit
                                              #245420
                                              colin hawes
                                                @colinhawes85982
                                                There is a huge difference in the useful life between a properly hardened tip and a cheap one. Colin
                                                #245648
                                                Clive Hartland
                                                  @clivehartland94829
                                                  Walking around B & Q today and seeing packs of driver bits at low prices I would not even bother to try and recover the damaged ones.
                                                  At 10 for about £3.50 is it worth it?
                                                  #245653
                                                  Mike Poole
                                                    @mikepoole82104
                                                    Now that woodscrews all seem to be hardend the attrition on screwdrivers or bits seems to be severe, building my workshop using a drill driver showed how short the life could be of even decent quality bits. Fortunately reasonable quality bits are not outrageously expensive and should be replaced when wear becomes an issue.
                                                    #245654
                                                    Bob Brown 1
                                                      @bobbrown1
                                                      Some boxes of screws even come with a new bit
