Rescuing a 920 lathe!
Home Forums Workshop Tools and Tooling Rescuing a 920 lathe!
Viewing 25 posts - 1 through 25 (of 48 total)
  • #340621
    Andrew Tinsley
      @andrewtinsley63637
      At last I have the Chester 920 lathe in my workshop. seems in good condition and requires the usual upgrades.
      it came from a fellow modeller who has been stricken with Alzheimer disease. He has unfortunately done some very strange things to the machine including throwing away the splash back and gear cover door. This isn't much of a problem, but he has done some even stranger things with the motor and associated pulleys!
      The pulley wheels are mounted on what is called a Bracket plate (part nos P4000201) which is screwed to the side of the headstock. Now this bracket plate has been thrown away! I have most of the bushes and all of the pulleys.
      Can anyone who has a 920 do dimensioned sketch of the bracket plate? The hole positions for the pulley bushes and idler gear is really all I want. I would buy a bracket plate from Chester, but they need a picture of the spare part, which I have not got!
      I just hate trying to lay out something like this. I always seem to get it wrong! However I might just have to give it a try.
      Andrew.
      #18844
      Andrew Tinsley
        @andrewtinsley63637
        #340644
        Oldiron
          @oldiron
          Hi Andrew Sorry cannot help you with this but I am sure some one will have some kind of answer soon.
          regards
          #340645
          John Rudd
            @johnrudd16576
            Andrew,
            The bracket plate is secured to the head stock casting with a number of socket head cap screws…
            I can measure mine next time I am back at the other house ( up for sale..) but in the mean time,
            The motor drives an idler pulley,which also houses the clutch for screwcutting, the idler runs in a slot to provide primary belt tension.
            The motor can also drive the main spindle directly, the upper 3 speeds…using the large 710 belt
            Do you have the belt tensioning assembly too?
            Edited By John Rudd on 09/02/2018 19:47:03
            #340646
            michael howarth 1
              @michaelhowarth1
              Have a look at Steve Bedair's 920 website.
              Mick
              #340650
              Andrew Tinsley
                @andrewtinsley63637
                Hello Old Iron,
                It is all a bit of a puzzle, certain things have been dismantled ,like the change wheel set up and the pulley system! He has made a direct drive to the headstock from the motor, which is screwed to the bench rather than bolted to the machine!
                It is no use asking the poor chap, as one is very unlikely to get any sort of answer, unfortunately.
                I can make the change wheel bushes and set that up, because the holes are extant. But the pulley system is a bit more difficult. I am going to have to make a new bracket plate and play with the existing pulleys and pulley wheels to get some idea where the pulley bushes go.
                I think it is one of those jobs that will be easy as soon as you get stuck in. Too much thinking probably makes the job seem much worse than it actually is!
                Thanks,
                Andrew.
                #340651
                Andrew Tinsley
                  @andrewtinsley63637
                  Deleated!
                  Edited By Andrew Tinsley on 09/02/2018 19:53:56
                  #340654
                  Andrew Tinsley
                    @andrewtinsley63637
                    Hello Mick,
                    None of the 920 websites including Steve Bedairs actually shows anything much of practical use. I have – the manuals from Grizzly and Chester and again one can get a rough idea of where the pulley bushes go, but it is a bit of a fiddle!
                    Thanks,
                    Andrew.
                    P.S.It would be a shame to break the lathe and sell it as spares, it has had very little use.
                    #340656
                    Redsetter
                      @redsetter
                      I think Amadeal still supply the 920 lathe, so may have a more sensible spare parts service than Chester.
                      #340658
                      Andrew Tinsley
                        @andrewtinsley63637
                        Hello John,
                        I missed your post! That really is kind of you! Some measurements would make the job so much easier! I am missing the belt tensioner wheel , but have the lever and spring and I believe the correct bush for the job. The Chester manual shows an excellent exploded view of the tensioning arrangement and that should be easy to copy!
                        Send me a PM when you have time to take a look at your 920. I really think I should return it to original condition. I am going to give the lathe to an impecunious friend, if I can get it sorted. I can help him do the mods and alignment etc.
                        Once done it is actually a rather decent lathe. But you need to spend quite a bit of time rebuilding it. Another friend had a 920 which was fully sorted and a joy to use, unlike the machine from the box! Pity he sold it, otherwise I would have been over there with pencil paper and ruler!
                        Thanks again,
                        Andrew.
                        #340663
                        Redsetter
                          @redsetter
                          I have just been out in the cold to have a look at my 920, but I think it would be difficult to measure accurately enough without dismantling.
                          To be fair I have always found Chester quite helpful by phone or email if you contact them directly and explain what you need.
                          The belt tensioner is a bit hit and miss, and does not work equally well in all positions, so don't feel obliged to copy it exactly!.
                          #340672
                          Vic
                            @vic
                            Could a three phase motor and invertor be an option instead of swapping pulleys?
                            #340813
                            Andrew Tinsley
                              @andrewtinsley63637
                              Thanks Redsetter and Vic,
                              I appreciate that it is difficult to measure up with pulleys in place and I don't expect anyone to dismantle their set up just to take measurements! However, even some very rough and ready measurements are better than none.
                              If I do get the lathe up and running, I may well do a conversion to VFD drive as I have a spare 3 phase motor and an old inverter hanging around the workshop and I could do with the space! The reason for this is that the slowest speed on the lathe with the conventional pulley set up would be just over 100rpm, which is on the high side. Just putting a VFD on the existing direct drive would be a bit limiting in range of speeds.
                              Thanks again,
                              Andrew.
                              #340816
                              Vic
                                @vic
                                It’s never straightforward is it Andrew. Good luck with the Lathe whatever you end up doing. They are a nice lathe once set up.
                                #340868
                                michael howarth 1
                                  @michaelhowarth1
                                  If I get a chance tomorrow I will photograph my lathe set up for you and try and put in some dimensions. You will at least then have some photographs for Chester. I have always found Tony a very nice man to deal with. I would second the 3 phase inverter drive being fitted……it totally transforms this lathe.
                                  Mick
                                  #340888
                                  Redsetter
                                    @redsetter
                                    OK, but no guarantee – please check!.
                                    Bracket plate 8 mm thick, 230 mm front to rear, 220 mm top to bottom, ignoring the curved section which projects down over the motor. Front edge is on C.L. of headstock spindle, Top edge is 3 mm below top face of headstock.
                                    Motor spindle to idler spindle 115 mm centres. Headstock spindle to idler spindle 205 mm centres. Where these arcs cross is the position of the idler spindle on the bracket plate. The hole is oversize to allow adjustment.
                                    Belt tensioner arm pivot to idler spindle 55 mm centres, and they are in line horizontally.
                                    Belt tensioner lever pivot to arm pivot 35 mm centres. The hole is 40 mm diameter and centered 28 mm from the bottom edge of the bracket plate. The vee belt is Gates no. 5M710.
                                    I think that's about right – hope it helps, and maybe Mick H can confirm.
                                    #340893
                                    Andrew Tinsley
                                      @andrewtinsley63637
                                      Thanks Mick and Redsetter,
                                      Those dimensions are great and I won't be upset if you are a little out! I will speak to Tony at Chester, just in case they would have a bracket plate . I should think that is about one of the unlikeliest spares to carry for the 920. Hence I didn't really have much hope that Chester would have one, but worth asking, one never knows!
                                      Thanks again,
                                      Andrew.
                                      #340899
                                      Les Jones 1
                                        @lesjones1
                                        Here is a picture of the drivebelts on my Chester DB-10G before I modified it with a 3 phase motor and VFD
                                        I think it is similar to the 920 lathe so it may be some help.
                                        Les.
                                        #340967
                                        michael howarth 1
                                          @michaelhowarth1
                                          I wouldn't argue with anything that Redsetter has given you in the way of dimensions. The set up that Les Jones has photographed is pretty much the same as my 920 except that the belt tensioner bears down on the top of the drive belt. I took some photos this morning but because of the positioning of my lathe it was very much a case of pointing the camera and hoping that something useful was snapped. I think I mentioned that my lathe is inverter/variable drive and I would never go back to the original set up. With variable drive you do not need the upper pulley / clutch setup which would normally be driven from the motor via a toothed belt. The drive is taken from the pulley set on the motor direct to the mandrel pulley. I loop the belt over the centre drive pulleys and don't even use the belt tensioner so I have a built in clutch. I used to get through quite a lot of those drive belts before I fitted the variable drive and they are now mighty expensive. Touching wood, I have not replaced a belt in 2 years since fitting variable. I think that you said you have an inverter/motor…….if you use that you do not need a backplate and in my opinion you will have a much better, more tractable machine. A piece of 8mm mild plate would suffice to fill the gap. If you wished to incorporate the belt tensioner, the design is a bit crude with loads of latitude for a positioning bolt. Have a look at my set up and I will be happy to answer any further questions. Ihope this will have been of some use. Mick
                                          #340970
                                          John Rudd
                                            @johnrudd16576
                                            Andrew,
                                            I have genuine Gates 710 belts if you need one or two, but not at machine supplier prices. Contact me via private message if you need to.
                                            #340986
                                            Andrew Tinsley
                                              @andrewtinsley63637
                                              Hello Les and Mick,
                                              Thanks for the help and encouragement. Mick your suggestion of just using the 3 step pulleys and a VFD has really put the cat amongst the pigeons! I would like to get speeds between 50 and 2000 rpm. Is this feasible without running the motor too slowly (cooling concerns)? I suppose I could work it out, but it is easier to ask!
                                              Thanks again,
                                              Andrew.
                                              #340990
                                              John Rudd
                                                @johnrudd16576
                                                Posted by John Rudd on 11/02/2018 14:24:15:
                                                Andrew,
                                                Just been and checked….the belts are 730 not 710. Although some of the 9 x 20 lathes were fitted with the longer blt like mine…..Sorry for the mis-information.
                                                #340992
                                                Redsetter
                                                  @redsetter
                                                  As a matter of interest, does anyone know the difference between the 920 lathe that uses the 710 belt and the one that uses the 730, as the belt length is fairly critical?
                                                  #340997
                                                  michael howarth 1
                                                    @michaelhowarth1
                                                    Just guessing really, but I suspect that it has something to do with the motor mounting.
                                                    Mick
                                                    #340998
                                                    michael howarth 1
                                                      @michaelhowarth1
                                                      Andrew, I have had no problems running mine at low speeds. I do not have any expertise in inverter / motor technology but I suspect that it will depend on your outfit. I am pretty sure that some knowledgeable person on this site could answer the question for you in more detail. Having said that, with the original setup you are going to get a speed of between 100 – 120 rpm anyway and that can be more than just annoying when you only want 50. I am probably talking rubbish but what about an additional 12v cooling fan eg from a computer? It seems to me that you have not got a lot to lose by trying it out.
                                                      Mick
                                                      Edited By mick H on 11/02/2018 17:26:04
