car boot tragedy
car boot tragedy
Home › Forums › Workshop Tools and Tooling › car boot tragedy
  • #242381
    Paul Barter
      @paulbarter66156
      Hello all, I thought I had a stroke of luck at a car boot near me, found a nice clean, unrusted Dormer adjustable reamer. However when I got it home I found a chip on one of the blades. My question is, are spare blades available?or is a chip on only one of the bladesof no consequence?Thanks to anyone who responds.
      Paul
      Edited By Paul Barter on 11/06/2016 19:51:27
      #18119
      Paul Barter
        @paulbarter66156
        reamer blades
        #242385
        roy entwistle
          @royentwistle24699
          Try it and see
          #242387
          MW
            @mw27036
            Roy is right, you could try it on a scrapper and see what happens, if your lucky the chip will not matter if it only means it doesnt make full contact on part of the material. If the chip is on the start of the taper it might make it harder to cut to begin with.
            Michael W
            Edited By Michael Walters on 11/06/2016 21:16:07
            #242388
            Paul Barter
              @paulbarter66156
              Hello Roy
              Thanks for responding, I am a bit concerned that the chip will produce a ridge which may not be removed by the other blades.I will try it on a trial bore.As a new,albeit not Dormer, djustable reamer seems to be available for £15 or so I wondered if replacement blades were available, along the lines of those fitted to portable electric planers
              #242390
              Vic
                @vic
                I would have thought it a good idea to round off the sharp corners of the chip first to prevent possible scoring.
                #242394
                Tony Pratt 1
                  @tonypratt1
                  I can't see that a chip on one blade will be a problem, I doubt if spare blades are available but I stand to be corrected.wink
                  Tony
                  #242396
                    If its along one edge rather than near the end, you should be OK. Might be worth stoning teh chipped area in case it has a raised burr.
                    Bob Stevenson
                      @bobstevenson13909
                      …Back when I was a very poor young man I made a couple of blades for some old adjustable reeamers….still got them somewhere… I used some 'ground steel stock' , what they now call 'gauge plate' in the right thickness and after careful hardening in the forge on a shovel and tempering in the ash they worked fine……..If I recall, I made the head stock for a amall lathe with them.
                      Edited By Bob Stevenson on 11/06/2016 21:57:00
                      Edited By Bob Stevenson on 11/06/2016 21:57:19
                      #242411
                      Speedy Builder5
                        @speedybuilder5
                        I don't think I would worry too much, I have some reamers that only have cutting flutes on about 240degrees of the circumference – they cut OK.
                        BobH
                        #242414
                        Paul Barter
                          @paulbarter66156
                          Thank you all for your enlightening comments.I continue to be grateful for the generosity of the members of this site and the breadth of knowledge that is so willingly passed on. Thanks again to all of you.
                          Paul
