BB22 Headstock Lathe Bearing
Home Forums Manual machine tools BB22 Headstock Lathe Bearing
  • #13111
    Colin Whittaker
      @colinwhittaker20544
      Documentation for changing a headstock bearing
      #334586
      Colin Whittaker
        I have a Model BB 22A Cutting Machine manufactured by the Beike Machine Tool Factory of Bengbu Machine Tool Industry Company.
        Although my Chinese lathe is working well enough I can feel a little shake on the headstock bearing and I think I may have to change it. The documentation that came with the lathe is pretty minimal but I think the offending item is a 15 x 32 x 9 bearing. Can anyone point me towards any step by step guides for this repair job on this specific lathe? Any youtube videos?
        #334739
        Brian Wood
          @brianwood45127
          Hello Colin,
          I can't help directly, but is this another version of the ubiquitous mini-lathe?
          If so, there will be plenty of information,U tube videos and the like on bearing adjustment and changing on those. Even if it is not, that general approach should give you quite a lot of information about how to approach the work on your own lathe.
          Brian
          #334744
          Richard Marks
            @richardmarks80868
            Contact Ketan at Arceurotrade, he knows all about these things.
            #334758
            Brian Wood
              @brianwood45127
              Richard,
              Isn't it being somewhat unreasonable to expect Ketan to provide the information for a lathe model Arc do not sell, even if it is another clone of the mini-lathe; which as yet isn't a known fact? He is very helpful on their own products but for a foreigner—–?
              I think it is up to Colin now to follow what may be all he needed to get him started.
              Brian
              Edited By Brian Wood on 01/01/2018 13:08:41
              #334804
              Richard Marks
                @richardmarks80868
                Brian
                My answer was intended to help Colin with his problem, Ketan at Arceurotrade is an expert on Bearings and he sells all types of them, I have had problems with various bearing related problems over the years and Ketan has come up with the answer everytime, As Colin has the measurements of the bearing Arceurotrade should be his first call.
                Richard
                #334989
                  Posted by Brian Wood on 01/01/2018 10:35:22:
                  Hello Colin,
                  No it's rather bigger by the look of it (~8 1/2" centre height).
                  Click the blank and an image will appear.
                  Colin Whittaker
                    Neil,
                    That's the beastie.
                    From my manual it has the following specifications …
                    height of spindle centre 110mm
                    max swing diam over bed 220mm
                    max workpiece diameter over carriage 115mm
                    max length of workpiece between centres 450mm
                    max cutting length 420mm
                    spindle bore 20mm
                    taper of spindle bore Morse No. 3
                    I have looked for similar generic Chinese lathes but I seem to have something a little too special.
                    I guess I'm going to have to bite the bullet, savage a perfectly good allen key to fit in the gap between chuck and headstock, remove the three jaw chuck, and then cautiously go boldly.
                    Cheers.
                    #335068
                      .Posted by Neil Wyatt on 02/01/2018 19:34:27:
                      Hello Colin,
                      Neil,
                      I think you may be confusing 'swing with centre 'height' surprise
                      From your link:
                      MODEL BB-22A-1
                      Cutting Capacity
                      Max. swing diameter over bed
                      #335089
                        Video of one working.
                        Looks like a mini-lathe on steroids!
                        Ketan Swali
                          @ketanswali79440
                          Posted by Colin Whittaker on 31/12/2017 09:39:00:
                          Hi Colin,
                          If it is the same lathe as in SOD's link, then it looks like a good heavy kit. I would like to suggest that the headstock bearings are bigger than the specifications you state: 15 x 32 x 9 (6002-zz or 2RS). These bearings are more likely to be some countershaft bearings perhaps or some mistake?
                          If your spindle has an MT3 taper, then the spindle bearings are likely to have a bore of 30mm or greater.
                          Does your manual have some kind of exploded parts diagram? Could you take a picture and post it on here?
                          Have a closer look at where the chuck is mounted. Is it mounted onto a separable backplate or is the chuck mounted directly onto the spindle flange?
                          Is the chuck an 80mm chuck?
                          Can you open the side gear box, take a picture of that area and post it here?
                          If it is a mini-lathe on steroids, then the principles of dismantling should be similar. However, the 6 step speed suggests some kind of belt drive, in place of the hi-low gear arrangement to be found on the original brushed motor mini-lathe.
                          If it is similar to a mini-lathe, this guide may help you, although the bearings may be a little different, and there may not be a countershaft for high low speed gear change. Also here is the Link to full dismantling of a C3 (not SC3).
                          Ketan at ARC
                          #335569
                          Colin Whittaker
                            Ketan,
                            Sorry for the tardy response, I can't really offer any excuse except to say I'm retired and refining my procrastination.
                            Based on your argument it does look as though the headstock bearing I need to replace could be item 46, a 36 x 62 x 14 mm bearing.
                            The chuck is secured by a series of allen bolts to a round plate that looks to be integral with the shaft drive from the headstock. A second plate is secured by allen bolts to the casing of the headstock.
                            I'm worried about damaging things when I remove and replace the bearing. To a lessor extent I'm worried about opening it all up and then finding I have the wrong replacement part and having to wait a month while mail order does its stuff in Thailand.
                            Pictures follow below.
                            Cheers, Colin
                            #335580
                            Colin Whittaker
                              Ketan,
                              Sorry, typo on my bearing size, it should read 35 x 62 x 14 mm.
                              The following link is the nearest I can find to a replacement, **LINK**
                              I'm not looking to save a few pennies here so guidance on a more expensive better quality replacement would be appreciated.
                              Colin
                              #335591
                              Ketan Swali
                                @ketanswali79440
                                Hi Colin,
                                The key bearings appear to be Fig. 46 and 47, which translate as follows:
                                Russian/Chinese No.46107D = International No.7007A P6 (ABEC 5) – Angular Contact Ball Bearing
                                Russian/Chinese No.46108D = International No.7008A P6 (ABEC 5) – Angular Contact Ball Bearing
                                Most bearing dealers outside Russia and China will easily recognise the international numbers. However, what may be tricky will be to find contact angle 'A', with P6 (ABEC 5) precision, where contact angle A = 30 deg., B = 40 deg., and C = 15 deg. (ref.NACHI Bearings).
                                Generally, 'B' is easily available is general grade, and 'C' is easily available in high precision. For your particular lathe, your max speed is considered to be 'low' when it comes to bearing selection. You will not necessarily need high precision P6 (ABEC 5), if you look for a good Japanese brand from a well known local supplier. So, your choices are for example:
                                NACHI/NSK or similar Japanese brand : 7007B and 7008B – general purpose Angular Contact Ball Bearings, or
                                if you want high precision, commonly available are:
                                NACHI/NSK-RHP : 7007C P4 (ABEC 7), and 7008C P4 (ABEC 7). (Note: P4 is higher precision than P6, but as it is more in production, it can be cheaper than P6)
                                The high precision bearings are designed for running at high speeds…. much higher than the max speed of your lathe.
                                I have avoided mentioning SKF, as, unless you buy from an authorised guaranteed SKF dealer, it is very easy to end up paying for fakes. Also, I know that the brands I have suggested above along with other well known Japanese brands are more popular in Asian markets, available at reasonable price.
                                Also, depending on when your machine was manufactured, and on what machinery the bearings were manufactured, it is often the case that in earlier times, the Chinese 'D' (P6 precision) was similar to current Japanese general purpose precision – P0.
                                Translations for other bearings in the list are as follows:
                                1000802 = 61802 also known as 6802 – Deep Groove Ball Bearing
                                102 = 6002 – Deep Groove Ball Bearing
                                8104 = 51104 – Thrust Ball Bearing
                                107E = 6007 P5 (ABEC 3) – Deep Groove Ball Bearing
                                8101 = 51101 – Thrust Ball Bearing
                                A word of caution: Only buy the bearings you need after dismantling, because what it says on paper can sometimes be different to what is fitted.
                                Also, with reference to the Angular Contact Ball Bearings, note the way in which they were fitted – i.e. which way around, before you take then off.
                                Good Luck,
                                Ketan at ARC.
                                #335826
                                Colin Whittaker
                                  Guru Ketan,
                                  Thank you for that carefully worded reply. The technical level you used suits me just fine. MiSUMi Thailand looks to be a convenient local supplier, **LINK** but I will first pull things to pieces as per your advice.
                                  Is there anything I can do to repay your kindness? Anything you need from Thailand? I'll be visisting the UK in a month or so.
                                  Best regards, Colin
                                  #335859
                                  Ketan Swali
                                    @ketanswali79440
                                    Colin,
                                    The link you sent looks good to me. At the end of the day, even if you get a good Chinese brand (e.g. LYC or HRB), or a reputable local Chinese bearing supplier, that will be just as good, as making bearings above 30mm bore requires a factory which has expensive large machinery investment. If you are unsure of the Chinese brand/supplier, or if you don't want to take the risk, stick to the known Japanese brands suggested, which include NACHI, NSK, KOYO
                                    There is no repayment of any kindness necessarysmiley. This is a forum where everyone tries to help wherever they can. If you are coming our way, drop in and say hello.
                                    Ketan at ARC.
                                    #335865
                                    Journeyman
                                      @journeyman
                                      Posted by Colin Whittaker on 03/01/2018 06:27:16:
                                      Cheers.
                                      Colin, are you sure that the chuck isn't screwed onto the spindle, just looking at the photos I immediately thought the lathe was similar to the many 920 types which have screw on chucks. The access for an allen key is fairly limited and would be an unusual fixing from my limited experience. Unfortunately the drawing doesn't help.
                                      Colin Whittaker
                                        Ketan,
                                        Thought I'd let you know …
                                        My son finally chivvied me into stripping down the lathe and replacing the bearings.
                                        The bearings were the sizes you advised.
                                        After reassembling the lathe the headstock shake is reduced but still detectable. This seems to be because there is no way to adjust the preload. I'm now waiting for some bearing shims to arrive.
                                        Thanks again for you assistance.
                                        Colin
                                        #597593
                                        Ketan Swali
                                          @ketanswali79440
                                          Glad to read you are getting there. smiley
                                          Ketan at ARC
                                          #631157
                                          Will Beattie
                                            @willbeattie68959
                                            Hi Colin et al,
                                            I'm retired now and have added a CNC capability to my RF30 Mill (Rong Fu) and now I'm learning how to use my BB22-1 Lathe properly, which was also mothballed for 25+ years.
                                            But, my problem is I can't find my BB22-1 manual and while hunting the net – I found this thread and have subscribed.
                                            The threading cutting info has worn off my machine and your photos look like they may give me all the ratios I need. But what I'd really like is a copy of the BB22-1 manual if you or anyone else could help, I'd appreciate it.
                                            Kind regards from the "lock down capital of the world
                                            Will Beattie
                                            Victoria, Australia
                                            #631180
                                            John Hinkley
                                              @johnhinkley26699
                                              Will,
                                              It would seem that your lathe is similar, if not identical to mine, another Asian clone. I have a pdf copy of the lathe. I also have made a clarified chart of the change gear table as shown below: (the one in the manual is, shall we say, unclear)
                                              Where Z1 is spindle output, Z2 and Z3 share the intermediate shaft on the banjo and Z4 is the gear on the leadscrew.
                                              PM me your email address if you would like a copy of the manual.
                                              For Colin,
                                              In order to facilitate the removal and replacement of the chuck, I made three mounting screws from new Hex head bolts with threaded collars Loctitied on to them, so that the hex protrudes beyond the rear face of the spindle flange. Thus an ordinary ring spanner can be used instead of the angled, truncated and often lost Allen key can be used. Like this:
                                              chuck bolt
                                              John Hinkley
                                                @johnhinkley26699
                                                Just re-read my post above. It's a pdf copy of the lathe MANUAL that I've produced – not the lathe itself! Now that's something I'd like to see.
                                                Will Beattie
                                                  @willbeattie68959
                                                  Hi John,
                                                  Thanks for your help.
                                                  Also IMO, your chart for the Gear Change for the BB22 is excellent as is your drawing of the actual chain.
                                                  Thirdly, I made up a special "Allen Key" tool to get the chucks off – but I'll be plagiarising your Chuck Bolt design too.wink
                                                  IMO another fantastic idea!
                                                  cheers Will
                                                  #641015
                                                  Rob Robson
                                                    @robrobson
                                                    Hi everyone.
                                                    I hope it’s ok to jump in on this post.
                                                    My son gave me a lathe that’s badged as a Chester.
                                                    it looks like a clone of the BB22 lathe.
                                                    it originally had a mill attachment on the rear of the bed, my son removed that to make a stand alone milll.
                                                    The reason for my post is, the lathe only has one belt fitted. It goes from the motor straight up to an idler pulley.
                                                    Can anyone tell me what size belt/belts do I need to make it usable please?
                                                    Also, can anyone tell me where I might find a manual, if one exists.
                                                    Thanks in anticipation.
                                                    Rob
