Warco Major or WM16B
Home Forums Manual machine tools Warco Major or WM16B
  • #342144
    Limpet
      @limpet
      Hi all
      I'm looking at upgrading my Chester Conquest mill to either the Warco Major of the WM16b is there any out there that I can get opinions for or against. After dealings with Chester I will avoid their offerings. Many thanks in advance
      Lionel
      Edit misplaced words
      Edited By Limpet on 18/02/2018 19:02:33
      And spelling
      Edited By Limpet on 18/02/2018 19:03:40
      Limpet
        @limpet
        #342267
        Thor 🇳🇴
          @thor
          Hi Lionel,
          I have an old milling machine similar to the Warco Wm16b although mine has a brushed motor. The WM16b has a brushless motor that has more torque than mine. My milling machine has served me well for six years without any trouble.
          The Warco Major is a round column mill and it is easy to loose centring if you have to move the head up/down the column. If you want something bigger than the Wm16b you might have a look at Warco GH18, almost the same price as the Major, and the GH18 has a dovetailed column.
          Thor
          #342274
          Trevorh
            @trevorh
            Hi Lionel,
            I have the WM 16 just coming upto 1 year old and very happy with its capability as well as the length of the table
            I liked the fact that it has the square column but also has the tilt facility, I had the extra long Table fitted to it
            only negative is I wish i had fitted a power feed but maybe later I will
            cheers
            Edited By Trevorh on 19/02/2018 15:51:46
            #342291
            Limpet
              @limpet
              Many thanks Thor & Trevorh for the feedback.I hadn't thought that hard about the round column but can now see it will be an annoyance to say the least, I discounted the GH18 due to the limited longitudinal traverse (360mm) I need min 400mm.
              So I will be ordering the 16B – unless someone says differently!!!!
              Many thanks
              Lionel
              #385248
              KenJ
                @kenj
                Hi Lionel,
                Did you purchase the 16B and if so, what is your verdict?
                KenJ
                #385253
                mechman48
                  @mechman48
                  Like Thor I have a WM16 with the long table, bought in 2012, so far it has served me well, I don't flog it with heavy d.o.c. so for me a good buy. Let us know how you get on with it.
                  George.
