Now on to the negative aspects of the D4000.
Overall, in comparison to my Emco C5 and PD400, the D4000 is in many respects, a poor substitute, suffering from multiple weaknesses, that in fact have made me regret the purchase. The issues that have emerged, as I've put demands on the machine, are as follows:
1. The first shock came when the bed began to scratch and dent in a very similar way to lead or soft Aluminium. On one occasion when I slid the tailstock back, several particles came away from the top edge of the prismatic bed, leaving a visible defect. The bed has progressively seemed to pick up dings and marks from no-where, despite the almost obsessive use of custom made wooden lathe boards, from day one. It is undoubtedly the softest lathe bed I have ever encountered and if it is hardened, I would be very, very surprised. If you brought the D4000 bed up against a Cadbury's Caramel that had been in the fridge, I believe that the lathe bed would mark more easily. A lightly fumbled Allen key on the Emco does nothing to the bed(I don't mean dropped, just very gently brushed against). On the D4000, it means a dent or a small chip. Considering the care that I have put in to protect it, I did not expect to have any marks at all on the bed.
2. The lathe is significantly less rigid than the Proxxon PD400 and even my Compact 5, which uses plastic gibs! With the saddle locked, a dti mounted on a magnetic stand, placed on the cross slide, measures 0.12mm or about 5 thou of movement, when you gently rock the topslide. This does not include any movement contributed by the saddle. A big weakness of the design is the omission of a simple gib clamp, in order to lock the slides. I have never seen a lathe without these and assumed there would be some way to do, what is, a basic need, of keeping the slides rigid when they are not in use. Last week I had a dig in during parting off 16mm 316 bar. I had locked the gib screws on the top slide and the saddle was clamped. This did little to make things more rigid. This lathe really struggles with rigidity and for that reason alone I wouldn't mind swapping it for a Cowells. I emailed Wabeco, suggesting several improvements, but have received no reply.
3. Related to the rigidity, the surface finish is awful, when you do the same operation as you've just done successfully in the Emco C5, using the same material, tool and tool post. Having measured the sloppy set up, I now understand where this is coming from.
4. The lathe vibrates heavily at 60% speed in the higher gear, generating a resonant shake that can be felt throughout the house.
5. The lack of leadscrew hand wheel is a significant omission that makes life difficult when turning simple jobs, let alone complex ones. Without the handwheel, you have to rely on the taper slide for accurate longitudinal measurements. This would be ok if the taper slide was pinned at zero. It isn't, so every time you loosen the taper slide, you must, by necessity, put an outboard mounted dti to clock it in, which takes a long time, when you've got several chamfers to cut. Even then you often end up with 4 thou tapers on 50mm long work, that you had thought was parallel. This is probably the biggest disappointment with the lathe, apart from the lack of rigidity.
6. The bed had several defects in the ground ways, probably casting voids.
7. The chuck back plate has a smaller through hole than the headstock bore, so in practice it can't pass a 20mm bar with the chuck in situ.
8. The tailstock overhang results in a heavy bias on the leading edge of the tailstock. This feels in use, to be exerting unnecessary wearing forces on the bed and tailstock, but just on the lefthand side of its base.
9. The V belt from the motor is noisy in one part of its rotation, resulting in a repetitive high pitch rustle.
10. The top slide mounted tool post stud is pressed in and pinned from the underside of the taper slide. On the other lathes that I've used, the stud was replaceable, meaning you could change tool posts and install a variety of accessories without modification. The D4000 would benefit from a standard M8 tool post stud which just unscrews, like the Proxxon PD400 or Emco C5.
So in summary, if I had my choice again, I'd avoid the D4000 and buy a Cowells for precision work and a used PD400 for the bigger stuff. To my knowledge, there aren't any other quality lathes out there that are made in the EU and under £3K. If I do find one, hopefully I'll Ebay the Wabeco and get a lathe that is more of an all rounder. If you are looking to the D4000 as an upgrade in capability and rigidity, you will be disappointed. Either get a PD400 or a good used Austrian Compact 8 or a Maximat.
Many thanks, Nick.
Edited By Nick anon on 22/05/2016 01:14:20
