Hi Dave,
Heating – use a propane burner generating about 7 kw of heat eg Sievert 2941. Get the whole joint upto temperature
Flux – use a long life flux eg HT5
Alloy – use low temperature 55% silver alloy 1.0-1.5mm dia
Heat the joint from the outside and apply rod on the inside or cut a small length of rod and place on the inside. When the alloy melts it will flow towards the heat creating a strong joint.
If necessary hold the pieces together with soft wire to allow expansion and prevent distortion.
Use vermiculite board and/or bricks to build a small hearth.
All products readily available.
For general advice see "Best Brazing Practice" on the website http://www.cupalloys.co.uk
regards
keith
