Thread Wires.
Thread Wires.
Home Forums General Questions Thread Wires.
Viewing 25 posts - 1 through 25 (of 35 total)
  • #26324
    Alan .204
      @alan-204
      #383646
      Alan .204
        @alan-204
        I would like to learn how to use thread wires I’ve a set of PD wires machinery’s hand book lots of good intention but for the life of me I can’t seam to figure it out, I assume you can measure metric threads as well as imperial ? I ask as it will be mainly metric I’ll be using now I’ve change to a metric lathe, just because it’s eaisier .
        Alan.
        #383662
          Alan .204
            @alan-204
            Thanks Michael I’ve read through it but it doesn’t help me I’m afraid, to much for me to try and take in, I could do with an example of how you measure the thread from start to finish using the wires on a M12
            Alan.
            #383667
            Alan .204
              @alan-204
              The penny’s drops when you take another look at what your doing, when measuring a metric thread with the wire method it helps if the constant you take away from your measurement is the metric one and not the imperial one 😡😡😡😡😡😡😡😡 you know that feeling when you feel like a complete dick, hope that’s the last one for a while.
              Thanks anyway Michael, Alan.
              #383668
              JohnF
                @johnf59703
                Alan, a couple of links here — **LINK**
                The first show how to – the second the calculations to find the over wire dimension
                Hope this helps John
                #383674
                John Reese
                  @johnreese12848
                  Measuring threads with wires requires three hands and a good deal of manual dexterity. Dropped wires can hide for eternity in the chip pan. A much handier solution is thread triangles.
                  http://www.fowlerprecision.com/Products/Thread-Gages/526033030.html
                  I was fortunate some years ago to find thread mikes at decent prices. If you can afford them they are the best way to measure pitch diameters.
                  #383702
                    Posted by John Reese on 04/12/2018 01:50:51:
                    dont know Does the kitchen double as your metrology lab ?
                    devil MichaelG.
                    P.S. … I see from another post, that you are in the US.
                    We may therefore be 'separated by a common language' destroying the joy of ambiguity.
                    Edited By Michael Gilligan on 04/12/2018 08:28:46
                    #383720
                    jimmy b
                      @jimmyb
                      These are what you need!
                      I've got a spread sheet that works everything out if you put in the effective thread diameter. If you are interested, message me your email and I'll send it you.
                      Jim
                      #383722
                      not done it yet
                        @notdoneityet
                        I’v got some older versions – a spring loaded coil which are for discrete threads. All Imperial – they are likely not made that way for many a year, so pre-metric offerings.. Have I used them regularly? – No! Only of use if one does not have a nut to trial fit.
                        #383729
                        jimmy b
                          @jimmyb
                          nidy are these the ones you refer
                          Jim
                          #383734
                          not done it yet
                            @notdoneityet
                            Mine are similar to those. Clearly still on offer and quite expensive for a comprehensive set.
                            #383740
                            Tony Pratt 1
                              @tonypratt1
                              Using thread wires isn't that difficult, practice & a dab of grease to hold the wires normally does the trick.
                              Tony
                              #383802
                              John Reese
                                @johnreese12848
                                Michael G,
                                No, my metrology lab is not in the kitchen. SWMBO will not permit metalworking tools in the house. I have a 24' x 30' shop in another county along with a 400 sq, ft. house.
                                I assume the term chip pan refers to something in the kitchen in Brit-speak. Please enlighten me.
                                What do you call the tray under the lathe that collects most of the swarf?
                                I have learned quite a bit of the terminology that is used in the UK from this forum. I would like to learn more.
                                #383805
                                  Posted by John Reese on 04/12/2018 17:41:49:
                                  Chip pan : **LINK**
                                  https://en.m.wikipedia.org/wiki/Chip_pan
                                  … as opposed to swarf tray
                                  It's rather like bonnet vs hood, or boot vs trunk
                                    What do you call the tray under the lathe that collects most of the swarf?.
                                    It's a pan for cooking chips.
                                    You are thinking of a swarf tray.
                                      Blimey … there's a helluvan echo in here
                                      angel MichaelG.
                                      #383829
                                      RRMBK
                                        @rrmbk
                                        in the US Chips are our crisps and Fries are our chips. and ive never seen anything yet in my swarf tray / chip pan that looked even remotely edible!!
                                        #383833
                                        Alan .204
                                          @alan-204
                                          The needing of three hands is a pain in the you know what when using thread wires, buts there’s another way if your interested, all I do is when I want to measure say an M12 thread I use an already made M12 piece of thread it holds the wires perfectly and you can sort of roll the wires with your thumb and finger if you see what I mean, it’s quit easy compaired to any other way I’ve seen, give it a go you may be surprised.
                                          Alan.
                                          #383870
                                          John Reese
                                            @johnreese12848
                                            Great idea, Alan.
                                            #383873
                                            ega
                                              @ega
                                              Here is a suggestion from the late Cliff Bower:
                                              An unattended chip pan was the means by which my mother twice set fire to her kitchen.
                                              #383877
                                              Hopper
                                                @hopper
                                                I am surprised this many people use thread wires in the home workshop. Why? Is the conventional thread depth calculation plus a bit of "try and fit" at the final stages not precise enough for some types of home shop work? Or is it simply for the joy of knowing that it's "spot on"?
                                                #383880
                                                not done it yet
                                                  @notdoneityet
                                                  As I see it, they are only useful for situations where good thread engagement is required but the two interacting parts cannot easily be test-fitted with each other.
                                                  #383881
                                                  Paul Kemp
                                                    @paulkemp46892
                                                    Posted by Hopper on 04/12/2018 23:51:11:
                                                    I know not! Plenty of examples on here of people chasing 2/10 of a thou when 2 thou or sometimes even 12 thou would be perfectly acceptable. I imagine there must be a lot of shadow graphs tucked away in strictly temperature controlled garden sheds and the calibration bills for measuring equipment must be horrendous.
                                                    Paul.
                                                    #383887
                                                    Hopper
                                                      @hopper
                                                      Posted by not done it yet on 05/12/2018 00:09:30:
                                                      Even then, I'll usually make a "test bung" and turn the thread to fit that. EG, if turning a chuck backing plate, make a male threaded plug that fits one of the existing chucks nicely, then screwcut the new backing plate until the threaded plug is a nice fit.
