tallow sticks
tallow sticks
Home Forums Workshop Tools and Tooling tallow sticks
  • #412949
    Paul Davies 16
      @pauldavies16
      does anyone know where to obtain tallow sticks. we used them when i worked for the MOD for tapping blind holes. the tallow acted as a lubricant and also as the tap went down the tallow got forced out along with the swarf allowing the hole to be tapped to its fullest depth. i cant find any reference to them on the internet.
      Paul Davies 16
        @pauldavies16
        #412951
        Speedy Builder5
          @speedybuilder5
          not quite the same, but we used lard when I was an apprentice. Tends to whiff a bit after a year or two on the bench !
          #412952
          Brian Sweeting 2
            @briansweeting2
            You can get tubs of tallow from places like Amazon. Fill the hole with a spatula of some sort.
            #412959
            Massimo Dalmonte
              @massimodalmonte45801
              If you happen to be traveling in northern France or Belgium, look for "Blanc de boeuf" (it is used to fry Pommes frites), inexpensive (3.99 Eur 1 kg).
              Massimo
              Edited By Massimo Dalmonte on 06/06/2019 16:41:43
              #412963
              Adrian 2
                @adrian2
                Any decent plumbing merchant should have it in a pot.
                Adrian.
