Hi, I have nearly finished machining the cylinder of a Stuart 10v and need help with a couple of points
1) What size of hole do I need to drill through the side of the valve chest for the intake and what size and kind of fitting should I use to fit into it.
2) What size of hole should I drill through into the cylinder for the exhaust and what size and kind of fitting should I use to fit into it.
3) And also what diameter should the holes be for the drain cocks.
Hope this makes sense to somebody out there. This is my first attempt at machining a model steam engine and thought I would start on what looks like the most difficult piece and as I haven't finished it yet I have no photos to post at the moment, hopefully as I progress some will follow.
Joe
