Source of hardwood base material
Home Forums General Questions Source of hardwood base material
  • #206837
    Tony Martyr
      @tonymartyr14488
      I have finally run out of my stock of hardwood and need a engine base around 12×8 by 2 inches thick. The stuff I have used in the past was a heavy dark Fijian wood which suffered from water staining but otherwise looked good and was oil resistant. I have done the usual web search but have rather lost my nerve (!) so seek recommendations for this forum
      Tony
      Tony Martyr
        @tonymartyr14488
        #206838
        david homer
          @davidhomer12226
          Tony
          I bought some from British Hardwoods some years ago, not sure if they have minimum order quantities. They are in Keighly West Yorkshire, might be worth giving them a call, google British Hardwoods and you will find their website.
          David
          #206839
            Assuming you want a block of solid wood then have a look at some of the wood turning suppliers they sell "bowl blanks" which would give you a 12x12x2 slab. (don't get a round blank! ) Good choice of hardwoods so should be able to find something thats suitable.
            I tend to run out a strip of something suitable and mitre the corners and fix around a piece of MR MDF, keeps the weight down and allows for any plumbing under the base, add a bit of a moulding with the router to tart it up a bit.
            Edited By JasonB on 06/10/2015 17:45:19
            #206840
            JA
              @ja
              I have happily used Robbins in South Liberty Lane, Bristol. They are specialists in marine timbers and hard woods. I have found them very helpful and they are quite happy to talk to the 'small guy'. They have a good web site http://www.robbins.co.uk but they are not cheap.
              JA
              #206843
              Bazyle
                @bazyle
                You are in danger from warping from anything that large so I'd go for Jason's suggestion but using decent ply not MDF yuk spit. If you are anywhere near a boatyard perhaps they would have some offcuts of marine ply and teak trim. If you took a photo of your engine along they would be more sympathetic to a fellow craftsman.
                Following the craftsman angle you might track down a woodworker by asking local artists and craftspeople. I got a nice lump of chestnut for a lamp base a couple of years ago from a bespoke furniture maker.
                Final possibility is a broken Windsor chair if you keep an eye on skips.
                #206850
                Speedy Builder5
                  @speedybuilder5
                  Talk to kitchen fitters. Big lumps of wood and other materials get thrown away when they cut out for hobs, sinks etc. Apart from bread boards, they are mainly junked by the professional.
                  #206857
                  Roderick Jenkins
                    @roderickjenkins93242
                    John**LINK** Boddy at Boroughbridge. Have a nice self selection store of planed planks. Not too far if you're visiting Bradford
                    HTH
                    Rod
                    #206859
                    KWIL
                      @kwil
                      Try mail@markarbon.co.uk local furniture maker in Bishops Castle, uses local hardwoods, should be good for an offcut.
                      #206863
                      daveb
                        @daveb17630
                        I noticed some bits of Ash in our local Tesco household section, about 10" dia X 2" thick.
                        Roger Provins 2
                          @rogerprovins2
                          Posted by JasonB on 06/10/2015 17:44:19:
                          Wood for turners in 2" square lengths (and many other sizes) are known as spindle blanks rather than bowl blanks.
                          #206867
                            Roger Tony wants a piece 12" x 8" x 2" thick to mount a model on. Its better than buying a whole plank and not too difficult to rip 4" off one edge of a 12" x 12"bowl blank to get the required 12×8 piece
                            #206869
                            Jon Gibbs
                              @jongibbs59756
                              Ockenden Timber can't be far from you… **LINK**
                              Their bowl blanks are round but they also list carving blanks which might fit the bill.
                              HTH
                              Jon
                              #206885
                              Ian Welford
                                @ianwelford58739
                                Sadly John Boddy at boroughbridge sold up and then closed down.
                                If you're in North Yorks then Duffields at melmerby are a good source. Also Scawton sawmills near Sutton-under-whitestonecliff. Further away there's Snaiton. Or at Doncaster there's Turners retreat.
                                Styles and Bates, down south do mail order and come highly recommended.
                                However ply and laminating as per Jason would be your best bet I think.
                                If it can wait and you're local the Northern Woodworking expo at Harrogate is on 20-22 November and there's always a good choice there.
                                #206905
                                Gordon W
                                  @gordonw
                                  Cheapest by far are local auctions- old brown furniture still does not sell. I get an old chair, sometimes as scrap, ideal for file handles etc. and one-use mandrels
                                  #207044
                                  Ian S C
                                    @iansc
                                    The last one I did was made by taking a bundle of strips of heavy plywood (somewhere between 15 and 20 mm thick), and cut it in strips about 1 1/3" wide, then glued it together with the edges as the top surface, just needs sanding down, then varnished. The joinery factory that was just around the corner has moved away, so my supply of free timber has gone.
                                    Ian S C
                                    #207495
                                    Tony Martyr
                                      @tonymartyr14488
                                      Thanks for the help – through these replies I found Ockenden Timber which is a treasure trove of kiln dried timbers and is only 20 minutes by car form home.
                                      I bought a slab of American black walnut – not cheap but exactly what I wanted and I resisted the temptation provided by their display of woodworking tools
                                      Tony
