Evidently, there are many instances when materials behave `badly’.
Heading slightly off topic, this reminds me of the phase change in PTFE (Teflon), which only `surfaced’ for me when I was making small valves for biological research. Refer to my album – `A Plastic Valve'
The body of the valve was PMM (Perspex) and the spools were PTFE. The success of the valve came from its leak resisting performance. A primary requirement to achieve this was selective assembly between the bore of the PMM body and the PTFE spool. Even minuscule differences in their respective diameters could cause the spool to be too tight or conversely, they would leak.
It needs to be noted here that PTFE in its natural state (ie. no filler), has a low creep resistance so that a marginally oversize spool will become `squashed’ over time.
As with most materials, a change of temperature causes the volume of PTFE to increase or decrease correspondingly. However, at 19 degrees C, there is a phase change, causing the volume of this material to increase sharply. Expansion then continues at a rate similar to that below 19C.
I had developed the valve for use at around 38C although one particular series of experiments required that the valve as supplied, had to perform at temperatures in the range of 5C to 15C.
That was fine except that they couldn’t be stored above 19C while assembled due to their low creep resistance. I had to sell them with the spools removed, and with instructions to store them refrigerated after assembly. Prolonged storage above 19C would ruin the requisite degree of fit.
