To solder (braze) successfully it helps to understand how it works.
Soldering refers to the process whereby pieces of metal are joined by melting another metal (the solder) so that it wets the joint and holds it securely when it freezes. That's basically it, but there are a few "gotcha's".
The important word is "wets". It's just like water. Put a nice clean pipe in water and freeze it; it's then difficult to get the pipe out, but use an oily pipe and it's much easier. The difference is that the water wetted the clean pipe, but couldn't wet the oily one. If the pipe wasn't oily but dirty, the effect would be the same. Solder works in exactly the same way. So all you have to do is make sure the joint is nice and clean and you'll get a good joint, right? Well, no, it's a little more complicated than that, but not a lot.
To melt the solder you have to heat it up. The trouble is that the very act of heating it also makes it dirty. The oxygen in the air is only too eager to oxidise everything it touches, and, as far as solder is concerned, metal oxide is dirt. Most metals oxidise rather slowly at room temperature, but heat them up and the effect is very rapid – so rapid as to make soldering impossible, unless you prevent the oxygen from reaching the hot joint.
There are only three ways to do this: solder in a vacuum, solder in an atmosphere devoid of oxygen, or coat the joint with an oxygen barrier that can withstand the heat. The first two options are rather impractical, but the third is fine; the barrier is called a flux. The job of the flux is to cover the joint with a barrier to stop the oxygen from oxidising it. Resin is a good flux for soft solders, and borax for hard solders or brazing. If the joint and the solder are nice and clean then these fluxes work rather well, but that's all they do; they are known as inactive fluxes. If the joint is a little dirty these simple fluxes do nothing except act as a barrier, but there are others that can do a small amount of cleaning too. Baker's Fluid is one such active flux for soft solder and EasyFlo is one for hard solder. The active fluxes are certainly better than the inactive ones, but they are not magic, you shouldn't rely on them to do the cleaning for you. Active fluxes usually contain some rather toxic and dangerous additives (potassium biflouride?) which do the cleaning bit.
So, now you have a nice clean joint and a flux, so it's plain sailing, yes? Well almost. Most problems are caused by heating the solder rather than the joint. All that happens is that the solder melts, goes into a ball, and refuses to flow into the joint because it freezes before it can wet it. The secret is to heat the joint, not the solder. When the joint gets hot enough it will melt the solder which will then flow nicely into the clean, fluxed joint. The final thing that can go wrong is to burn the flux. If you heat the flux for too long, longer than a minute or so, it will lose its properties and allow the oxygen to pass. This is normally the result of insufficient heat, so if it happens, remove the heat, clean the joint, and start over, perhaps with a better source of heat, or better insulation to prevent the heat from leaking away. If you can't get the joint up to temperature with adequate insulation then you need a greater quantity of heat – ie. a bigger flame. Your photos show that you aren't using enough heat to get the boiler hot enough to melt the solder.
So, the four main points for a good soldered joint are:
1. Make sure the joint and solder are both clean.
2. Use a good appropriate flux.
3. Heat the joint not the solder.
4. Complete the joint quickly.
I hope this helps.
Gary
