Separating front and back pressure gauge
Home › Forums › General Questions › Separating front and back pressure gauge
  • #492339
    Half centre
      @halfcentre
      Hi folks – I was wondering if anyone had any tips for separating the front and back of small pressure gauges. With the two I have the back slides into the front telescopically. This seems to be a very common fitting. The fit is very tight and I have yet to find an "easy" way to separate the two halves to enable me to mark the red line on the scale.
      Any thoughts gratefully received
      Martin
      #27586
      Half centre
        @halfcentre
        How to?
        #492470
        Zan
          @zan
          Hold the outlet vertically in the vice. The mech is usually attached to the body “cup” then carefullyAnd gently punch the bezel off. Worked perfectly on all mine
          #492595
          Half centre
            @halfcentre
            Thanks Zan – That sounds an excellent idea – I will give it ago.
            Martin
            #492837
            Nigel Graham 2
              @nigelgraham2
              Thank you both Half centre for asking, and Zan for replying: I am faced with the same difficulty!
              I think I would use a scrap of semi-rigid plastic or wood, possibly aluminium, as punch.
              #493004
              Half centre
                @halfcentre
                Just tried it and it worked a treat. Gentle tapping with a small hammer and an aluminium rod as a punch. Careful to move it around the circumference to get an even movement. Found 2 raised pips formed on the inner casing I presume deliberately to create grip. Sanded them a little flatter, grip still adequate but now far easier to separate.
                Thanks again Zan
                Martin
