Rob Roy stretchers
Rob Roy stretchers
Home › Forums › Beginners questions › Rob Roy stretchers
  • #7149
    Ian Horsfield 1
      @ianhorsfield1
      Help from those who have made this loco
      #151754
      Ian Horsfield 1
        @ianhorsfield1
        Not long started a Rob roy but need confidence in design of one of the stretchers. The drawing show a semi-circular cut and one of the books shows U cut out. Which is best and I assume the cut out is on the off-side of the engine. Please can you assist?
        Ian.
        #151761
        AndyP
          @andyp13730
          If you mean the cut out in the rear stretcher for the boiler blowdown valve then mine is U shaped about 7/16 deep and 7/8 wide. It is on the left hand side of the engine looking forwards.
          Whilst thinking about stretchers I had to mill pockets in the underside of the large central stretcher to clear the eccentric straps but that might be my slightly agricultural straps.
          Andy
          #151791
          Ian Horsfield 1
            @ianhorsfield1
            Many thanks Andy, that answers my questions and I shall investigate clearance for the eccentrics. Ian
            #154681
            Ian Horsfield 1
              @ianhorsfield1
              Forgot to ask if the u shaped cut out on the Rob Roy stretcher is on the top edge or bottom edge. The cut out is apparently on the left side looking forward. Can you clarify before I get cutting and fixing.
              ian h.
              #154761
              Phil H 1
                @philh1
                Ian,
                I haven't assembled my frames but I have the Rob Roy book which seems to indicate the top edge for the cut out. If you look at the drawing showing the boiler backhead – you should see the blowdown valve which would clash with the top left hand side of the vertical stretcher as you look forwards.
                PhilH
                #154762
                AndyP
                  @andyp13730
                  I concur, top edge.
                  Andy
                  #154807
                  Ian Horsfield 1
                    @ianhorsfield1
                    Thanks Phil and Andy. It was well worth checking before assembly.
                    Ian.
