RDG or Myford ER32 collet set?
Home Forums Workshop Tools and Tooling RDG or Myford ER32 collet set?
  • #389746
    Peter Turvey
      @peterturvey44018
      Whats the difference between the RDG and Myford ER32 2-20 mm 18 piece collet and collet chuck sets? Apart from some £30 in price they look very similar. The former is described on the website as Myfiord thread and the latter for small bore Myfords like mine. So not sure which one to get.
      Peter Turvey
        @peterturvey44018
        #389748
        Chris Trice
          @christrice43267
          I'd look at a Vertex set. Mid range price but excellent quality.
          Edited By Chris Trice on 06/01/2019 20:28:19
          #389749
          Emgee
            @emgee
            Hi Peter
            The RDG Myford ER32 chuck and collet set has a backplate that screws direct to the spindle and a collet chuck that bolts to the backplate, this allows work to pass through into the spindle bore.
            The other chuck has a MT so fits into the spindle and no doubt requires a drawbar for security in use. The length of rod inserted will be limited to slightly longer than the collet.
            My choice would be the backplate fitting type as once fitted to the chuck it would just need screwing onto the spindle and be ready for use.
            Emgee
            #389751
            John Haine
              @johnhaine32865
              Now I'm confused. RDG I think own Myford. So is there a difference?
              You can get ER32 chucks that have a taper, such as MT2 or MT3 or R8 and fit into a taper socket typically for holding milling cutters. Not very good on a lathe for workholding because (a) you can't pass material through into the h/s bore and (b) because of the overhang.
              Much better on the lathe as emgee has said is the type that fits on to a backplate that screws on to the spindle nose. This minimises the overhang and lets material pass through. Depending on your lathe either ER32 or 40. My S7 is the big bore type and I went for ER40 from Myford before they went bust. I tend to use it more that 3J or 4J chucks.
              #389754
              Marcus Bowman
                @marcusbowman28936
                +1 for Vertex. Mine have served me well.
                Marcus
                #389758
                Peter Turvey
                  @peterturvey44018
                  Posted by John Haine on 06/01/2019 22:17:07:
                  John thanks for your comments, Both sets have backplate fitting chucks, hence my confusion…..is the price difference just rhe Myford name I wonder?
                  #389813
                  John Haine
                    @johnhaine32865
                    Almost certainly! I can't see a backplate fitting chuck with c/w collets on the RDG site? You could also get an ER32 chuck with backplate fitting from Arc and make your own backplate.
                    #389837
                    Peter Turvey
                      @peterturvey44018
                      Thanks, here are links to the RDG site
                      https://www.rdgtools.co.uk/acatalog/ER32-COLLET-CHUCK-MYFORD-THREAD-WITH-FULL-COLLET-SET–2PC-SET–4353445.html
                      Funnily enough, I can not find the small bore collet chuck and collet set on the Myford site now. My Ipad shows it but the PC does not! Think it may be picking up an old cached version of the Myford website.
                      All is now explained, thanks all for your feedback.
                      #389844
                      ronan walsh
                        @ronanwalsh98054
                        I bought an er32 r8 taper collet chuck from rdg in november. It was marked myford. On inspection it seemed ok apart from the nut was stiff on the body of the chuck. The first time i used it was holding an edge finder. Found the edge and swapped for an end mill, 4 or 5mm in diameter. Took the cut and went to change to a larger tool, the nut slackened off a quarter turn and siezed solid.
                        I took the whole thing out of the machine and sent it back to myford. After about a week i emailed them and they told me the reason it seized was i did not know how to use it, the collet had sprung in behind the nut, which couldn't be removed, and they were returning it to me at a cost of £13 !.
                        Despite the myford name, i reckon they are the usual Indian tat, the nut and the body of the chuck were similar in hardness, galled and seized.
                        I won't be buying anything with the myford name on, and no more from rdg.
                        Buy a vertex, or a good, european, american or japanese brand, or see if you can find one second hand on ebay or here.
                        #390663
                        Peter Turvey
                          @peterturvey44018
                          Thank you for your comments everybody ; in the end I bought a RDG Myford collet set and backplate fitting chuck. I checked out Vertex suppliers but found that the collets alone were nearly twice the price of the RDG set. Not justified for my very occasional use. The RDG set is giving a runout of between 0.0005" and 0.001" seemingly depending on collet size, The taper in the collet chuck seems to be is running with about 0.0003" runout, I see from other threads that the collets themselves should have a .0005" accuracy.
                          Some of this may be due the backplate itself having a small runout as it does not seem as snug a fit on the spindle nose as my chucks.
