R8 COLLETS
R8 COLLETS
Home Forums General Questions R8 COLLETS
  • #25135
    ray jones 1
      @rayjones1
      R8 COLLETS
      ray jones 1
        @rayjones1
        Hi
        I am trying to purchase a R8, 12MM Square collet
        any ideas please?
        thank you
        ray
        #288549
        John Haine
          @johnhaine32865
          As R8 collets are made specifically to hold milling cutters with round shanks I think you'll be lucky to find one.
          #288550
          Nick Hulme
            @nickhulme30114
            Hmm, – http://www.arceurotrade.co.uk/Catalogue/Collets/R8-Collets/R8-Collets-Square-Metric-Sizes
            Sadly 10mm is their largest square collet, could you broach an emergency collet?
            #288556
              http://www.mhctools.com/proItem.aspx?id=1331
              offer squares up to 14mm
              [restless night, came down for coffee & spotted this query]
              #288560
              John Haine
                @johnhaine32865
                Good grief! I still wonder what the application is as I've never seen a milling cutter with square shank or R8 nose other than on a mill. Now I'll just wait for the next reply with details of both!
                #288565
                  John,
                  Although not commonplace … the R8 is a perfectly realistic option as a lathe collet:
                  http://www.homemetalshopclub.org/news/jul04/jul04.html
                  Chris Evans 6
                    @chrisevans6
                    Lots of import "Deckel" style cutter grinders offer R8 collet versions. I keep a few 5C square and hexagon collets for the lathe, I can see a use for them in R8.
                    #288743
                    ray jones 1
                      @rayjones1
                      Hi
                      thank you for the replies.
                      I have a tool grinder which has a small dividing head with R8 fitting.
                      If i use a 12mm sqaure collets can then easily grind 12mm lathe cutters
                      thank you
                      ray
