PTFE Rod
PTFE Rod
Home › Forums › Materials › PTFE Rod
  • #529333
    Vic
      @vic
      I’ve got to make some small parts from some 8mm PTFE rod. I’ve not machined this stuff for years. Luckily no turning needed just facing, drilling and parting. I’m guessing a very sharp HSS knife tool will be best for the facing?
      #30112
      Vic
        @vic
        #529344
        Tony Pratt 1
          @tonypratt1
          Yes a sharp tool is best for PTFE.
          Tony
          #529390
          Emgee
            @emgee
            I have found a HSS ground to suit aluminium works well with PTFE and other plastics, when using insert type tools the same applies, the polished inserts designed for aluminium work for me.
            Emgee
            #529396
            Martin Connelly
              @martinconnelly55370
              I've just finished some parts for someone who gave me some nylon plate for the material. Very very sharp tools work but the slightest wear and it was like machining toffee.
              Martin
              #529402
              Hillclimber
                @hillclimber
                I have recently turned both ptfe and nylon 6 spacers/ washers. Agree completely with Emgee comments on sharp HSS/ CCGT type inserts. And keep the speed up.
                PTFE was easy, the nylon just looked a bit more inclined to build on the cutting edge but never did….
                Cheers, Colin
                #529414
                Jon Lawes
                  @jonlawes51698
                  I recently saw a tip for working such material; it you are machining it down to 10mm (for example) then a quick cut with a hacksaw along the length of the rod almost to the machined depth will mean the swarf forms short pieces rather than one long mess which clags itself around tools and such.
                  #529428
                  bernard towers
                    @bernardtowers37738
                    That’s a good tip!
                    #529433
                    Mark Rea
                      @markrea67084
                      Wear a mask whilst machining PTFE. The dust is no good for you at all.
                      #529459
                      duncan webster 1
                        @duncanwebster1
                        And don't smoke, burning ptfe gives of poisonous fumes.
                        #530372
                        peter smith 5
                          @petersmith5
                          Connect your hoover so that the swarf and fumes gets sucked up the tube and not your nose.
                          pete
                          #531530
                          Martin Dowing
                            @martindowing58466
                            Posted by Mark Rea on 22/02/2021 21:39:05:
                            Dust like dust – not good but not very dangerous either.
                            What *is* important is to avoid smoking while machining PTFE.
                            Dust go to cigaret, undergo thermal depolymerization and very toxic gas known as perfluoroisobutene is formed.
                            It is about an order of magniude more toxic than phosgene, and even very small quantities can make one very sick or kill.
                            Canaries are dying in kitchens where housewives are carelessly using PTFE coated frying pans for a good reason.
                            Martin
                          Home › Forums › Materials › Topics
