Posted by Howard Lewis on 11/12/2019 12:14:16:
Folks, are we not making mountains out of molehills?
The OP was asking about a pipe between the tender and the locomotive.
Ah. Didn't see the reference to tender in the OP on first reading.
In that case, the answer would be "It depends."
Depends on the abilities of the feed pump or injector. If it has the ability to increase the pressure differential between the two ends of the pipe by a sufficient amount then increased pressure will create increased flow through the smaller pipe, as flow is proportional to pipe radius times pressure, (all other things being equal of course).
But, if – as is often the case – the feed pump or injector is only just up to the job with a 3/8 pipe, and can not provide sufficient extra "suction" or pressure differential, the 1/4" pipe will restrict water flow.
So, disregarding frictional losses which would be somewhat minimal in such a situation, you might as well plumb the whole length in 1/4" pipe if you are going to do one section in 1/4".
The question remains: why would you even need to reduce your feed line from 3/8 to 1/4 in one place anyway? Can't you just make a bigger hole for the 3/8 pipe to pass through?
