Posted by Andy Cameron on 15/09/2019 21:24:30:
… I was also thinking about single phase AC motors ? i.e. generator direct to AC motor ……..is that just to simple to be feasible obviously with some sort of ESC.
I'm not impressed by single-phase electric motors for this application. Compared with other types they have too many limitations: for traction their low torque (turning power) and difficult speed control are killers, on top of that they run bumpy with relatively poor efficiency. A DC Motor, Brushless or 3-phase motor will be much more satisfactory. As these and suitable controllers are all readily available I don't see any advantage in single-phase, only pitfalls.
Andy's problem is how best to match the output of an off-the-shelf 240VAC generator to a motor. Now that VFDs are affordable, I'd be inclined towards a 3-phase motor – reasonable torque, efficient and VFDs do a good job of speed control. However, even though it will easily out-perform a single phase motor my main concern would be a 3-phase motor's ability to shift a heavy load from a standing start. This is why IC engines need a flywheel, clutch and gearbox.
Indirect electric drive, for example when a generator charges a battery, which in turn powers a DC motor is a good compromise. The battery provides a high-current source which is good at satisfying peak demand during starting and acceleration.
These peak demands don't last long. Once an indirect drive vehicle is moving, the generator tops up the battery and then powers the wheels via the battery. Having a storage system deal with peaks means the generator can be sized to meet average demand, which is considerably less than the start-up demand. Get the sums right and the battery can also be quite small because it only works hard during starting. An interesting development in Hybrid Vehicles is the use of super-capacitors rather than batteries. Although a super-capacitor holds less energy than a chemical battery, it charges and discharges much faster at almost 100% efficiency. This makes super-capacitors attractive for stop-start operation and regenerative braking.
