Painting gloss
Painting gloss
Home › Forums › General Questions › Painting gloss
  • #603009
    Garry Coles
      @garrycoles69390
      Hi.
      Have just finished building my Stuart No 9 and I am in the middle of painting it using the Stuart gloss paints. The instructions on the tin says to leave for 24 hours before overcoating. But with gloss you usually should rub down inbetween coats to create a key for the next coat. But with such small parts, you can't get to all the surfaces. So, will the paint adhere to the first coat as the paint is still fresh.
      Garry
      #28749
      Garry Coles
        @garrycoles69390
        #603158
        bernard towers
          @bernardtowers37738
          Usually if solvent based the solvent from the second coat softens the first and gives it the key.
          #603171
          Robert Atkinson 2
            @robertatkinson2
            What Bernard said.
            The paint will not be fully cured after 24h. It's long enough to stop the wet paint lifting the "dry" coat off though.
