One-shot Myford lubrication system
Home Forums Manual machine tools One-shot Myford lubrication system
  • #442639
    JA
      @ja
      I am getting a bit fed-up with Myford oil guns and the lubrication of my big bore Myford. Ten years ago there was an article in the MEW about fitting a one-shot oil system to a Myford ML7. The parts came from Arc Euro Trade and for some time they sold a kit for the lathe.
      I would like to know if anyone fitted the system and, if so, what they thought of it. Better still, if anyone modified the system for use on a later Myford.
      JA
      JA
        @ja
        #442649
        David George 1
          @davidgeorge1
          Try Lubetech .co.uk they supply all the parts.
          David
          #442657
          Robert Atkinson 2
            @robertatkinson2
            Posted by David George 1 on 21/12/2019 11:36:04:
            David
            Hmm that takes me to a spill contol product site. Were they taken over?
            Robert G8RPI.
            #442661
            Dave T
              @davet19446
              It's actually lubetec.co.ukblush
              #442663
                Try dropping the aitch
                https://lubetec.co.uk
                Dave beat me to it
                Edited By Michael Gilligan on 21/12/2019 13:14:08
                #442669
                IanT
                  @iant
                  I think Arc still have a few of the required parts in their "Clearance" section.
                  I did think about this when the original article was published but frankly it seemed quite complicated to do every oiling point. I think if I was to do something like this, I would just try to supply the hard-to-reach points (like the back of the saddle) with a simpler system. Some of my other machines might benefit from this too – maybe as simple as an extended pipe to make the oil point accessible without breaking my neck or moving the machine.
                  IanT
                  Edited By IanT on 21/12/2019 13:49:47
                  #442976
                  JA
                    @ja
                    Many thanks for the replies. I am not taking this any further.
                    I am not sure if there is any experience with this system.
                    Looking at my lathe there are at least four oiling points that will give problems if oil feeds are attached –
                    1. Two in the gear train to the gearbox which will prevent gears being swapped between normal feed and thread cutting.
                    2. The feed on to the headstock belt pulley.
                    3. The feed to the top of the saddle which will foul the DRO sensor.
                    I see little point in having only half a system.
                    JA
                    #442992
                    KWIL
                      @kwil
                      I have fitted Hydraulic type grease nipples (used strictly for oil) to the carriage rear and front apron. Sealed carriage front (on top) point and drilled horizontally to match and fitted same for front shear lub. Base of tailstock modified for single point lub and fitted same. Oil cups retained where fitted and later Myford oilgun is quite suited to other points.
