I use Mint v.13 which has long term support to 2017. I have it on two computers, both with 2Gb RAM. I have also tried it on an old laptop, Toshiba Satellite Pro 4620 (or something similar) which has a small amount of RAM, something like 320 Mb or so. Unfortunately, the laptop is packed away in the loft so I can't readily check it, but from memory, it seemed to work.
Similar to other contributors, having escaped from Microsoft (I was a very happy user of XP) I will never go back – Mint, in general does all I want.
Programs I use:
Internet browser – Firefox,
Emails – Thunderbird.
Office stuff – Libre Office, but note that I only use Writer & Calc.
Graphics – Paint Shop Pro v.7.04(PSP) via WINE. I have had to adopt a fudge in order to have my main toolbar show all my desired icons. This appears to be because under Windows, PSP can save whatever state the main window is setup as, but this doesn't work under WINE. Instead I use the facility to import a Workspace. The program doesn't load from the Main Menu, but does load satisfactorily from the panel. I have not found any other major issues, but then I am not a power user. Photos, PSP pictures etc do sometimes automatically open PSP, but I find it easier to open PSP first, then search from within PSP for the required file.
CAD – Design CAD Pro 2000 (DC2K) via WINE. This is an old program, but it works extremely well in this configuration. I have setup a template for my desired layers & colours etc, and by using a startup macro can load it automatically. For some reason, native saved DC2K drawings are not recognised by Mint as such: instead, it thinks they are a Dreamcast Rom. Therefore, to load a drawing, I simply load DC2K, then within DC2K, I search for the drawing and load it. Job done.
I also have DesignCad v.17 (DCV17). Although the program will load and run via WINE, there are one or two semi-major problems which can be got around, but frankly, for my purposes, DC2K is easier to use. Interestingly, under Mint v.17, DC17 is much better, but does still have an issue with "File, Image" which can be a show-stopper unless I remember to avoid it. This suggests to me that the issue is actually WINE as my version of Mint 17 uses a slightly later version of WINE.
Finally, I use a DOS based database program (Mpro) via DOSemu. Along with some helpful advice from another forum on how to use DOSemu, Mpro works very well indeed albeit with the occasional problem with speed when searching through 220K records.
My advice? Go for it.
Peter G. Shaw
