Need to make a spring
Home Forums General Questions Need to make a spring
  • #23124
    Oompa Lumpa
      @oompalumpa34302
      Oompa Lumpa
        @oompalumpa34302
        Yes, I could possibly read a book, or do a search on Google, but where's the fun in that?
        So I managed to acquire this lovely little press that I am going to make some pretty specific tooling for as it will be perfect for the job I have in mind.
        It has one issue however and that is the return spring is broken, the clock spring I believe they are called. Now, never having had cause to make one of these, what would be the best way to go about this? As a starting point, what should I use for material?
        Couple of pics of the item in question:
        #142677
        Neil Greenaway
          @neilgreenaway71611
          Hi there,
          Is there any chance that a 2 stroke engine recoil spring could be adapted to provide return action? They are easy to obtain from garden machine service agents and not too expensive at just a few quid! Look at one from a small strimmer or chainsaw engine.
            Posted by Oompa Lumpa on 03/02/2014 20:27:08:
            … the clock spring I believe they are called.
            … what should I use for material?
            There's probably a good clue in the descriptive name that you used.
            Oompa Lumpa
              @oompalumpa34302
              Posted by Michael Gilligan on 03/02/2014 20:53:52:
              Yes, i know, bit ironic. I actually have quite a bit of material that could be clock springs but I make hair springs for it. Never made anything like this though. And the biggest my supplier has is about 3/32th
              Good call about the return spring but it actually needs to go around a full turn.
              graham.
              #142684
                Graham,
                Have you got the remains of the broken spring ?
                What width and thickness, and how many turns ?
                … I'm guessing that something from a mantel clock, or maybe one of those kitchen timers might do the trick.
                jason udall
                  @jasonudall57142
                  Counter weight
                  #142686
                  Robert Dodds
                    @robertdodds43397
                    Graham,
                    Look on Associated Spring web site for constant force springs. There is a large range of sizes in stainless if you have to resort to making from new.
                    Bob D
                    #142689
                      Of course … idea
                      The return spring for a small drilling machine is likely to be remarkably similar.
                      Edit:  Something like X0-15 here
                      Edited By Michael Gilligan on 03/02/2014 22:29:43
                      #142691
                      speelwerk
                        @speelwerk
                        For the thickness you can start with the rule of thumb that it is 1% of the barrel diameter, but do not know if that also go's for your press. Niko
                        #142693
                        JohnF
                          @johnf59703
                          Graham, If you want to try making one I would suggest EN45 or EN42 if you want more power but I would recommend EN45 its more forgiving. Don't know where you are in the UK but if I can help with HT please PM me, Below are some useful links — John F
                          John McNamara
                            @johnmcnamara74883
                            Hi Ompa
                            Easy…. Just buy one
                            john
                            #142721
                            Ian S C
                              @iansc
                              I made up one for a drill press a few years back, Had some clock spring (1/2"-3/8" can't remember), it was not strong enough, so I used two springs wound together, worked quite well. The spring in the starter in some chain saws could be worth looking at, you pull the cord, then to start the saw, you pull the trigger, and the spring turns the motor over, and usually starts it (much safer that the old way). Ian S C
                              #142728
                              IanT
                                @iant
                                I always keep the 1/2" steel banding that is sometimes used to 'wrap' the crates/boxes of heavier goods. I rescued 3-4 good lengths last year (I cannot remember for the life of me what it came wrapped around now – maybe a washing machine?) and it goes a long way & lasts me quite a while
                                Not sure if they are "clock" quality steel (or could be usefully coiled) but they do work well for hold-down fingers on my router table (much better than the useless plastic fingers supplied) or any other application where a flat spring is required. I cut them to length with a Dremel but don't try to drill them, simply making a slit metal clamp to fix them in place.
                                IanT
                                #142731
                                David Jupp
                                  @davidjupp51506
                                  Springs often fail at the anchorage (at one end or the other). A temporary (?) repair can sometimes be made by heating just the damaged end enough to soften it and allow forming of a new hook or loop.
                                  Stop heat from spreading along the spring by gripping with a large clamp or similar.
                                  #142734
                                  Oompa Lumpa
                                    @oompalumpa34302
                                    Posted by IanT on 04/02/2014 10:49:54:
                                    IanT
                                    This banding also makes excellent shim material and you can also craft superb lock picks from it. Not that I would know.
                                    Snag is,the press came without this spring and from my measurements cannot be bigger than 30mm diameter and 5mm wide so even the smallest advertised offering is too large. Though for three pounds I might well take a punt on one offered by an Amazon seller and take a grinder to it.
                                    graham.
                                    #142741
                                      Posted by Oompa Lumpa on 04/02/2014 11:21:54:
                                      Snag is,the press came without this spring …
                                      graham.
                                      Graham,
                                      Sorry if this seems pedantic … it is not gratuitously so.
                                      You said,originally, that the spring was broken …
                                      It is worth mentioning that both presses that I have, of this type, came from an Assembly Line [small, precision items] and all their presses had the springs removed … for the comfort and convenience of the operators.
                                      It will depend on the type of work you do with your press; but you my actually find it "handles" better without the return-spring …. Bargain Solution ??
                                      John Rudd
                                        @johnrudd16576
                                        How about using piano wire for a spring?
                                        #142751
                                        Pat Bravery
                                          @patbravery
                                          Last year I got through Amazon a bench press quill return spring for about £3, it came from China in about 8 days and fitted with no problems at all. They do a variety of sizes to suit. Well worth a look. Best regards Pat
                                          #142765
                                          Oompa Lumpa
                                            @oompalumpa34302
                                            "It is worth mentioning that both presses that I have, of this type, came from an Assembly Line [small, precision items] and all their presses had the springs removed … for the comfort and convenience of the operators.
                                            It will depend on the type of work you do with your press; but you my actually find it "handles" better without the return-spring …. Bargain Solution ??"
                                            You know what Michael, as I have not yet actually tried the task with the spring, I am going to just get on with it and see how it goes.
                                            I will carefully polish the ends of the tooling to reduce the risk of scratching the workpiece and take it from there.
                                            The links produced by JohnF were interesting though (although one supplier had a minimum order for half a kilo!) and specifically EMO Springs were a company that I had never heard of but look like they could supply some very interesting solutions to some problems I encounter occasionally.
                                            I saw a spring on Amazon for the same £3 Patrick and I will order one to see if I can make it fit, if not, it isn't the end of the world and I am in no rush. THIS is the one I was looking at.
                                            graham.
                                            Edited By Oompa Lumpa on 04/02/2014 16:09:53 – added link
                                            Edited By Oompa Lumpa on 04/02/2014 16:10:09
                                            #142893
                                            Ian S C
                                              @iansc
                                              The spring used in the self winding mechanism of an Electrolux cylinder type vacuum cleaner would be about the right size. Ian S C
                                              #142919
                                              ian cable
                                                @iancable23486
                                                hi try Meadows and Passmore Ltd in Brighton put the name in and there site will come up usual disclaimer just a happy customer
